I have a 2010 Scott Spark 10. Still in use. Great bike, super fast and ive never found anything i want to replace it with (TBF i do have other/newer bikes too)
Looking at upgrading the read shock. Its a DT Swiss Nude - 6.5x1.5 (165x38) by all accounts. Buying either the Monarch RL or Fox Float DPS. Sorted.
But where is the goto place for the bushings so i can peruse online? i think i need 22.2x6mm for this
I would maybe start with TFTuned, who I've used a lot
Here is there range, there are a lot of options:
https://www.tftuned.com/search/mount+hardware?search=mount%20hardware
Cheers.. sorted 🙂
I suspect this is too late, but if you are after the metal hardware rather than the DU bushings, I always buy from Bounce.
Very durable and reasonably priced. And you could even consider an offset one to get the bike a touch slacker & lower BB.
