Rear lights
Rear lights
21 Users
I lost my nearly new Exposure Trace-R yesterday going down Glen Ogle.
It was the thick end of £40 and tbh I wasn't that impressed with it. I need a replacement in true STW fashion what do you use?
Posted : 04/09/2022 5:05 pm
I’ve always found my Moon Nebula decent. You can mount it on a seat post on a saddle bag loop or bolt it to your saddle rails. Rechargeable - had mine quite a few years now - and it’s had lots of wet commuting.
Posted : 04/09/2022 5:10 pm
Second for the Moon - any of their strip lights are good. I have one clipped to my pack but have also run it on the saddle rails.
Live also got a Leyzene strip drive that is bright and works well.
Neither of them are coming off easily.
Posted : 04/09/2022 5:17 pm
Appreciated both. Will check the moon out.👌
Posted : 04/09/2022 5:37 pm
Yep moon good.
Knog blinder 9er is a bright small bit of kit.
Posted : 04/09/2022 5:42 pm
I like the Moon strip lights too. Lost my Garmin Varia between FodD and Scotland somewhere and replaced it with a Moon - feels very secure wherever it’s mounted.
Posted : 04/09/2022 5:44 pm
Another vote for the moon light. I have it strapped to the rear vents on my helmet.
Posted : 04/09/2022 5:45 pm
Moon nebula or the planet x knock off have been good for me. The saddle bracket has been good and very secure.
Posted : 04/09/2022 5:46 pm
Erm, TraceR.
Posted : 04/09/2022 7:35 pm
@martinhutch
This is exactly what i've done. Very visible and there regardless of which bike i'm riding.
The moon lights are generally very good and bright for the money.
Posted : 04/09/2022 9:26 pm
There's a clear winner. £7 postage at Planet X is a bit salty mark you.
Posted : 04/09/2022 10:53 pm
Agreed, four quid light - seven quid postage.
Posted : 05/09/2022 8:05 am
 cp
There’s a clear winner. £7 postage at Planet X is a bit salty mark you.
Agreed, four quid light – seven quid postage
Code PXFREECSPOST gets you free post.
Posted : 05/09/2022 8:12 am
It does indeed, cheers cp. 👍
Posted : 05/09/2022 8:16 am
@cp 😎
Posted : 05/09/2022 8:51 am
 aide
What moon light are people putting in their helmets? Sounds a very good idea to have as a 2nd option
Posted : 05/09/2022 2:46 pm
Just testing a Rockbros smart rear light Q5. Rechargable, brake light senses motion & works. Secondary light has auto off in daylight if req. Or set to all on.. Was £14 from Aliexpress.
Posted : 06/09/2022 10:28 am
I've been using a bontrager flare RT for a couple of years now.
Links up to my garmin head unit so it switches on when I power the head unit up. Battery life etc also displayed on garmin.
And they weigh nothing.
£34 at sigma just now.
Posted : 06/09/2022 11:14 am
Knog are brilliant imo
As are many other suggestions above!
Posted : 06/09/2022 11:56 am
The problem I found with the Exposure rear lights (I had the more expensive one cannot remember what its called) is that they popped out the brackets when using the dropper....this ultimately how I lost mine - nearly a hundred quids worth pinged off into the undergrowth somewhere never to be seen again
Posted : 06/09/2022 12:57 pm
I've got one of these (or probably an out of date version of it)
https://ride.lezyne.com/collections/led-lights-rear/products/1-led-8r-v204
Thats not coming off the seat post unless the whole rubber strap degrades into pieces.
It goes around the seat tube/the static part of the dropper though, so short people on 29ers may have issues with the wheel blocking the light. Can also clip to a bag if you wear one or on particularly foul muddy nights I have clipped it to my waistband
Posted : 06/09/2022 1:05 pm
Moon Shield X, nice light and no complaints. Had a Moon Shield before it, which lasted years.
Posted : 07/09/2022 8:45 am
PX Dogstars (I ordered X2) arrived yesterday.
Reassuringly retina searlingly bright. For less than a fiver I'm over the moon. Do you see what I've done there?
No more Exposure for me. A fool and his money etc..
Posted : 07/09/2022 8:54 am
I have a Moon Nebula too. It seems pretty good. My one grumble is that the switch is on the light side of it, and when I mount it to my backpack it often gets knocked on when I put the pack down. Having the button on the opposite face would be better, but other than that it seems good.
Posted : 07/09/2022 8:57 am
Ditto Merak (although I only ordered the one), fantastic for the dosh.
I've got a few of the PLANET X COB-28 USB R a little more than Dogstar but they also work great nice and bright, alloy casing, still good battery life even after a couple of years.
Posted : 07/09/2022 9:24 am
