REAR LIGHT WITH LAS...
[Closed] REAR LIGHT WITH LASER USES AA BATTERIES NOT AAA
3 Users
Looking for something like this
http://www.ebay.co.uk/itm/Bicycle-Bike-Cycling-Red-Laser-Beam-5-LED-Safety-Rear-Lights-Tail-Lamp-Battery-/151216507938?pt=UK_SportGoods_CyclAcces_RL&hash=item233534cc22
BUT all rear cycle lights seem to use AAA not AA. As AA have 3 times more power than AAA AND most shops are selling at the same or similar price they are poor value for money (AAA). I also note that with the lasers on the sellers claim only 9 hours output. As disposable lose voltage quickly I would assume that actual brightness may be insufficient before the 9 hours. My options are:-
1/ Lithium disposables, expensive.
2/ Rechargeable AAA dodgy as rechargeables lose there power quickly with no warning and I would have to remember to charge them. My memory is not my strong point!
3/ Lights that take AA rather than AAA and use Alkaline. At least with this option I should have adequate warning that the batteries need replacing.
4/ Any other options I have not thought of?
Posted : 28/01/2014 9:31 am
Presuming light is centrally mounted on seat post - do you have a saddle bag? Remote battery pack in saddle bag. if you did 4AAs (two series, two parallele) then you could have 5+ amp hour capacity. (5 times AAA)
If you are brave you could see if 3.6v is acceptible for a supply voltage, if so then you could get a couple of 18650 cells for 3.6v 5ah capacity.
Posted : 28/01/2014 10:03 am
Doh1Nut - Member
I may have a seat post bag. But have I got this right you are saying rewire the light? I must admit I like the idea but lack the knowledge for the wiring and would worry about water ingress. I would have no problem with 3.6 volt as I believe 1.5 volts is an average for AA peak would be higher.
Posted : 28/01/2014 10:20 am
I'd be surprised if that e-bay light lasted as long as the batteries to be honest!
Posted : 28/01/2014 10:30 am
Yes, it would require some faffing but as a proof of concept I would go to maplins or wherever and get a 2*AA battery holder. run the wires from that to the battery terminals inside the light.
Once you are happy that it works, you can start making it more permenant, drill a hole in the light for the wire to go through and seal it with silicone.
Get a 4*AA battery holder and switch round the wiring to get the correct voltage and increase your run time.
Get some connectors [url= http://www.componentshop.co.uk/leads-and-connectors/extension-leads/jst-bec-lead.html ]JST[/url] so you can remove the light.
etc.
Posted : 28/01/2014 10:40 am
.piedi di formaggio - Member
I have had some surprising good lights direct from China none have ever failed. All that ceased working were due to me breaking them. In fact they are all still working. I have either broken the attachment or broken the cover. Obviously i can't say that about everything I buy from Ebay that comes direct from China.
Posted : 28/01/2014 1:02 pm
