Rear hub question
[Closed] Rear hub question
5 Users
Just to be sure before purchase - all other things being equal if I currently run a rear hub with a QR skewer, can I change to a 10mm bolt through hub without any problems?
Thanks in advance.
Posted : 20/02/2013 6:16 pm
Yep I've used a hope hub with m10 bolts
Posted : 20/02/2013 6:21 pm
Depends weather the brand of hub you buy has that option.
Posted : 20/02/2013 6:51 pm
Sorry, maybe didn't explain too clearly - the hub has the option of the 10mm through axle, but I just want to check that it will definitely fit in the standard QR dropouts on the bike.
Posted : 20/02/2013 6:54 pm
It definitely will fit fine.
I've been using Hope Pro 2's for years now.
Used to run a 'bolt-thru' with a DT Swiss qr.
Now run a 'bolt-up' as pictured above - all on standard 135mm dropouts.
Posted : 20/02/2013 7:10 pm
Yes. I've used Pro2 like that, & now Surly SS hub with a solid 10mm axle.
Posted : 20/02/2013 7:24 pm
Many thanks all - order placed 🙂
Posted : 20/02/2013 8:18 pm
