Rear Brake Adaptor ...
[Closed] Rear Brake Adaptor on the front?
7 Users
If you took a rear 180mm IS rotor adaptor and fitted it to a set of IS mount forks, what size rotor would you need?
I've been sent a set of front and rear brakes with 203mm front and 180mm rear rotors, but the same adaptor with both brakes.
I don't have the rest of the bike to check the mounts with, so wanted to check before I contact the seller.
Thanks.
Posted : 15/12/2010 9:36 pm
200/203 on front - I reckon you're OK (unless yr fork is a weird "bigger" IS, but that wouldn't be the seller's fault)
I use them interchangeably, though mfrs tend to sell as though they're specific
Posted : 15/12/2010 9:39 pm
Rear STD mount is 20mm smaller iirc, so just add 20
Posted : 15/12/2010 9:45 pm
Cynic, you do rc.
Posted : 15/12/2010 9:49 pm
So it's a 200mm front mount rather than a 203mm mount?
I feel like I would want a 203mm mount for my 203mm rotor wouldn't I?
It's all Magura if that's relevant.
My new forks are Post Mount rather than IS, so I do need a new mount whatever, but if the mount is for the wrong sized rotor, maybe I can get it swapped.
Posted : 15/12/2010 10:15 pm
Sorry, logged in with my housemates account.
Posted : 15/12/2010 10:21 pm
it'll be OK - at the worst, a couple of thin washers'll lift it enough but I doubt you'll need it
Posted : 16/12/2010 12:05 am
Yeah, but I can't use that mount anyway as the one I need is post-mount, so if I'm within my rights to ask for a proper mount it might be useful.
Posted : 16/12/2010 10:14 am
The adaptors are size specific, especially the 203mm as it's also offset rather than just a spacer.
Posted : 16/12/2010 11:59 am
Contacted Leisure Lakes, who sold the brakes, they're sending the correct rotor (Post Mount) adaptor out next week. 🙂
Top service!
Posted : 16/12/2010 4:41 pm
Hope 183mm rear post caliper to IS mount is the same mount they list for 203mm front post calipr to IS mount.
Posted : 16/12/2010 4:50 pm
