Rear boost non boos...
[Closed] Rear boost non boost front
9 Users
Hi
I'm looking at a Nordest but noticed they are a boost rear , I have non boost forks is there any deals for non boost front wheel and boost rear wheel ? I know hope do them was looking for something a tad cheaper
Any advice would be fab
Posted : 14/10/2020 11:49 am
Im just using my non boost rear with some of those spacer things off ebay. works perfectly.
If i wanted a boost specific rear i'd probably buy the wheels separately.
Posted : 14/10/2020 11:54 am
I think I'd aim to go for something that can be adapted in case you want to change forks (or to be ready for the next new standard). Hope do this but obviously at a cost. Or just go mis-matched/second hand.
Posted : 14/10/2020 12:00 pm
Find someone in the opposite (probably more common) situation.
Posted : 14/10/2020 12:19 pm
non boost wheelset + adapator for rear. this iss what i`ve done.
boost is a load of tosh and pointless too.
Posted : 14/10/2020 12:55 pm
Probably not much help but I had same issue with my Yeti sb6 and got a wheelset built for a good price at the time (DT240 hubs 471 rims) as a german site were doing some decent custom build prices on DT stuff back then.
Posted : 14/10/2020 1:14 pm
If I use an adapter doesn't the rear need 'dishing' not even sure what that means
Posted : 14/10/2020 1:19 pm
https://www.amazon.co.uk/dp/B08C7ZFH87/ref=cm_sw_r_cp_apa_i_E0UHFbD7YGSAA
I bought this and it fitted perfect. Gorilla glued it to the existing adaptor and no dishing required.
Posted : 14/10/2020 1:24 pm
I will have a cheap Syncros Boost rear wheel for sale soon (27.5 30mm internal rim) been ridden twice if that is of interest?
EDIT: XD driver
Posted : 14/10/2020 1:25 pm
Thanks alanf but I'm still running 1x10
Posted : 14/10/2020 2:27 pm
Hunt allow you to mix boost and non boost. Bought a set of enduro wheels from them using this exact set up for my Cotic RocketMAX.
Posted : 14/10/2020 2:31 pm
If I use an adapter doesn’t the rear need ‘dishing’ not even sure what that means
nope - if you can run a regular spaced/offset chainring the chainline will be good. i have to run a boost spaced/offset chainring to clear my frame but its still fine.
get the spacers that sit either side of the hub and on the disk mount. i`ve glued the spacers to my frame so they dont fall out when i (very rarely) take the wheel out.
boost is so pointless its silly. there is no need for boost anywhere.
Posted : 14/10/2020 3:27 pm
