Rear boost axles, s...
[Closed] Rear boost axles, screw directly into frame?
5 Users
On my Felt Surplus 650B plus hard tail the rear boost axle screws directly into the frame i.e. not into a captive nut arrangement which can be easily replaced if stripped. Is this normal for boost rear axles?
Posted : 15/02/2018 10:20 am
Pretty normal for any rear axle tbh. The thread will be pretty chunky and you shouldn't be swinging off it, so thread damage shouldn't be a problem
Posted : 15/02/2018 10:28 am
Conversely all of my bolt through axles go into a threaded insert that's two 148x12's and one 142x12.
Posted : 15/02/2018 10:58 am
You sure it doesn't screw into the replaceable gear hanger?
Posted : 15/02/2018 1:06 pm
This definitely just screws directly into the frame and it's a fine thread so easily stripped especially as it screws in to tighten i.e. not a lever cam style.
Thanks Steve, likewise all my non boost axles screw into a captive threaded insert of some sort but this is my first boost width bike and I thought they were maybe all like this.
Posted : 15/02/2018 5:15 pm
 cnud
My Spesh boost screws directly into the frame. It has a fine thread as this is stronger than course and less likely to come undone.
Posted : 15/02/2018 7:07 pm
