Real dumbass questi...
[Closed] Real dumbass question...BB30 crank removal.
5 Users
OK, so im trying to remove the crank from my road bike to replace it, ive got the non drive crank arm off, but i cannot for the life of me get the drive side out. It appears that it should simply pull out, but it will not budge. Am i missing something or should i just MTFU and hit it harder?
Im not changing the bearings BTW, theyre fine.
Posted : 20/11/2012 9:21 am
 cp
They can be quite tight. Get it started by holding a block of wood over the non-drive side end of the axle, and knock it with a hammer. Gets it started (will get most of the way off the bearings), then it should just slide out, getting a bit stiffer again as a the non-drive side axle bearing surface passes through the driveside bearing.
Posted : 20/11/2012 9:27 am
i seem to remember having the same problem the first time i dismantled my stumpjumper. it looked like it should slide it but was unreasonably tight. the solution was indeed more vigorous whacking. slides out easily these days.
Yep - same issue here with xt cranks on the bb92 on my Stumpjumper. Was in a hurry so gave up in the end, but I could not get the crank out. Was really whacking the non-drive side end of the axle with a rubber mallet, but it wouldn't budge...
Might have to bodge a removal tool...
Posted : 20/11/2012 10:35 am
Well thats 2 hours of whacking the shit out of it, and it hasnt moved a millimeter!
Any more ideas?
Posted : 20/11/2012 10:37 am
put something soft on the garage floor for when it eventually gives and the whole crank flies out the drive side....
 cp
OK, that's weird. Any pictures? Is there a circlip around the axle on the non-drive side preventing it from moving? (my FSA Gossamer doesn't, but I guess they could) Any pictures of both sides?
Posted : 20/11/2012 2:18 pm
I FINALLY got the damn thing off, had to get the BFH out though...was rather scary, but now sorted.
Posted : 20/11/2012 6:58 pm
