Re routing brake ca...
[Closed] Re routing brake cable
5 Users
I've done this plenty of times, in fact i did it on said brake about a month ago.
But now i've changed shock i can't run the hose under the shock anymore as it's a fatter air can, so im having to run it under the swingarm.
Can i remove the hose from the lever (Avid) route it and fit it back on without needing to replace the compression olive or do i need to replace that when i remove the hose from the lever ?
Posted : 09/07/2012 6:43 am
Olives are supposed to be 'one shot' things - they change slightly under compression (hence the name). You may get away with it but for the sake of a 20p part I'd just make the change.
Posted : 09/07/2012 6:46 am
Personally I'd replace it, for the sake of a quid or two.
Pump the pads out a little, disconnect the hose and reroute it, reconnect and then push the pads/pistons back in...
Bugger.
Im not so much worried about the 20p, i trimmed the hose short when i did it last month so to change the olive/barb is going to make it even shorter....
Posted : 09/07/2012 6:48 am
I've re used them successfully.
Posted : 09/07/2012 6:51 am
Assuming this is an orange then?
Can you not undo the banjo fitting and re attach?
Posted : 09/07/2012 7:26 am
Hi,
Sorry went out to work after my first posts.
It's not an Orange no, a Trek.
I did wonder about removing the banjo fitting on the caliper, it looks removable.
Is that an option ?
Posted : 09/07/2012 5:31 pm
