I've got a rattling Apex left hand brake lever (Sonder Camino Apex 1x11 set-up). It's recently started rattling like crazy when on anything other than smooth tarmac.
Does anyone have a link to any maintenance guide for them? Or any ideas on how to stop it?
thanks
Evening bump
Do you not ride with your finger on the lever all the time?
I usually have my hands on the hoods as it's got flared drops. It still rattles.
anyone got any ideas?
I had the same issue with Apex, coincidentally on the same bike. If you pull the lever and look down the gap at the top, you'll see the hinge and there's a washer either side - that's the rattling. I tried injecting grease around them which cured the problem temporarily, but it came back. It annoyed me so much that I forked out for a new lever.
I had this Issue with my shimano brakes. Turned out to be the lever reach. As it was dialed in a bit it gave it some slack. Making it full reach gave it nowhere to move to and stopped the rattle.
thanks, I'll check over the weekend
