Rattle from reverb ...
[Closed] Rattle from reverb stealth hose on a carbon frame
7 Users
My reverb stealth hose rattles a lot on the inside of my carbon frame.
Has anyone solved this by putting some sort of sleeving on the hose?
If I pull the hose tight from the entry point it is then silent, but I am not sure whether that is a good long term solution.
Posted : 02/10/2018 12:37 pm
No rubber grommet where it exits the tube?
You could make one out of Sugru if you haven't got one.
Posted : 02/10/2018 12:41 pm
There is a grommet, but the hose is rattling in the down tube somewhere.
Posted : 02/10/2018 12:42 pm
Get a length of silicone tubing (available on ebay), slice it along the length of the tube then place it over the hydro hose, inside the frame > job done.
Posted : 02/10/2018 1:07 pm
you can fit small zip ties too, every 30cm of so - leave the tails stuck out at different  angles and they stop the hose moving about.
There was a long thread on here about foam tube to get to go around internally routed hoses and cable outers - search may find it.
Posted : 02/10/2018 1:09 pm
I used a length of foam rubber door frame insulation (stuff you use to close the air gap between your door and frame - a foam rubber tube) that I had kicking around. Did the job.
Posted : 03/10/2018 11:33 am
Foam tube (some bikes come with this on internal cables from new)
Zip ties round the hose but not cut off (Like Di2 anti rattle clips)
Posted : 03/10/2018 12:00 pm
 feed
The Jagwire stuff looks good, but nowhere has it in stock as far as I can find.
Have ordered some of this from China
https://www.ebay.co.uk/itm/183147616155
Posted : 03/10/2018 12:11 pm
