Rate my new bike
[Closed] Rate my new bike
24 Users
Been struggling to find a sufficiently cheap 29'' front wheel so put bits from my blue pig and spares box on my Gary Fisher Rig frame. Got a 29er fork on the way which should sort out the angles a bit.
Ride is 'interesting', but nowhere near as bad as you might think. Looking forward to taking around Swinley, although the BB is a [i]little[/i] low and the cranks are 175mm so I'm expecting lots of pedal strike.
Someone please sell me a 29'' front wheel.
Posted : 09/06/2013 8:04 pm
is the new fork rigid?
Posted : 09/06/2013 8:07 pm
Yeah, but 460mm a2c compared to these which are nearer 400mm
Posted : 09/06/2013 8:09 pm
At the moment. I'd have to give a 2 out of ten for the Matt black only. It looks dangerous! 🙂
Posted : 09/06/2013 8:11 pm
It doesn't have gears or suspension !! So normally thats a no for me. But I love "parts bin" bikes and a ride what you got mentality, so a big thumbs up.
The garage door's a nice colour and your drive's weed free.
Posted : 09/06/2013 8:14 pm
Slack chain 🙁
Posted : 09/06/2013 8:21 pm
It'll climb like a rocket! 😀 and descend like a wheelie bin...
Posted : 09/06/2013 8:34 pm
Goodness me ! 😯
Posted : 09/06/2013 8:49 pm
I quite like the bottle cage.
Posted : 09/06/2013 8:51 pm
Head angle, 89 degrees?!
Posted : 09/06/2013 9:51 pm
I like the way the chainstay points almost straight into the ground. That gets danger points from me for sure!
Posted : 09/06/2013 9:55 pm
Nowhere near enough gears.
Get some amberwall tyres on that.
3/10
could do better
Posted : 09/06/2013 11:10 pm
Faceplanters got it, OTB waiting to happen
Posted : 10/06/2013 3:07 am
Silver headset spacers Fail
Posted : 10/06/2013 4:46 am
Does it ride like you are continually going down hill but without the gravity boost?
Posted : 10/06/2013 6:11 am
It loses points as the rear valve/logo alignment is about 7° out. It should be smack bang of the Middle of the two "xx" like the front one. Could be fatal! Sort that then take new pic and I'll rate it then. 🙂 Oh and fit some real pedals on too. 😀
Posted : 10/06/2013 6:38 am
Forks too short, brake cables too long, chain too slack, very poor valve alignment, forks don't match the bike.
Apart from that, great. 😉
Posted : 10/06/2013 7:08 am
I think the front disc is a bit small at 200mm, pretty sure you could get some 240mm for the dowhill racing this is crying out for..
Posted : 10/06/2013 7:27 am
Rotors *look* like they're on back to front too (although the arms suggest not). I always think the 'teeth' should be at the trailing, not leading edge as they go through the pads.
Posted : 10/06/2013 7:30 am
Gears for queers fam.
Eyesight fail, those are some OG FSA crabon fibré spacers right there.
This is a valid point and will be rectified when I can be bothered.
This is not a valid point.
You're just pointing out the obvious, try a little harder.
I'm a little worried that the QR will get pulled out with anything bigger
Yeah, as you say, arms are correct, it's just the design of the rotor.
AYHSMB
Posted : 10/06/2013 8:25 am
I like the commitment of the pedals, it's quite a beast!
Posted : 10/06/2013 8:41 am
Probably looked nicer in the parts bin!!!
Posted : 10/06/2013 8:42 am
smiththemainman - Member
Probably look[s]ed[/s] nicer in the [s]parts[/s] bin!!!
FTFY.
Posted : 10/06/2013 8:54 am
Update!
Correct length forks have been purchased, and a front wheel is on it's way. Huzzah! Now, where's cheapest for 29er inner tubes?
Posted : 10/06/2013 8:12 pm
woodwork to the garage door frame needs sorting
Posted : 10/06/2013 8:26 pm
The angle of the [s]razor[/s] saddle has changed?
Otherwise I'm alright with any bike with some love in it, yours has some charm. It's got a good bake, could do with a splash of colour. May I suggest gold. 6/10.
Sort your wood out too 😉
Posted : 10/06/2013 8:45 pm
The angle of the razor saddle has changed?
Laziness of not adjusting it after adding 60mm to the a2c length.
Posted : 10/06/2013 9:10 pm
It's finished, hooray!
Posted : 19/06/2013 7:00 pm
