Ramin 3+ tubeless
[Closed] Ramin 3+ tubeless
6 Users
With yet another 10% off I finally gave in and bought myself the Ramin 3+ at the weekend.
It seems daft not to run it tubeless but having never set up tubeless before I'm not sure exactly what I need. The rims are WTB i45 scrapers so I think all I need are the right rim strips, valves and sealant. If that's correct then it's really just a question of which rim strips do I need for these rims.
If anyone can point me in the right direction I'd appreciate it
Thanks
Posted : 15/01/2018 10:35 am
Did mine just after I bought it ,I used Stan's 25mm tape , 2 widths to cover the entire rim , 2 X tubeless values , a good splash of sealant and they went up with a track pump first time 😀
They did fail once when I ripped the sidewall ,but now it's repaired with a tubeless kit ,it's been fine again
Posted : 16/01/2018 5:31 pm
Did my i45s with waterproof gorilla tape and tubeless valves.
Posted : 16/01/2018 5:58 pm
I replied in other thread but I used gorilla repair tape 50mm and two old valves cut from old tubes
Posted : 16/01/2018 6:00 pm
As per other thread, WTB say use tape 5mm wider than the rim.
https://www.wtb.com/products/tcs-rim-tape
Posted : 16/01/2018 6:12 pm
Mine came with the tape installed. Have you checked? Had two tubeless valves in the pack from Evans too
Posted : 16/01/2018 7:11 pm
Thanks all, thought this post had dropped away so started the more specific one.
Posted : 17/01/2018 9:01 am
