Raceface Evolve cra...
[Closed] Raceface Evolve crankset, do I need a crank puller?
5 Users
Hi chaps,
I've read a few manuals, and lots of threads. But not straight answer.
I'll have some 2014 Raceface Evolve cranks with rings soon. These are EXI interface, so external Isis.
Do these have a crank extractor bolt, in built? Or do they need an m22 crank puller?
Racwfave's website states both as possible methods. But its not clear if one or the other is right, or wrong.
Its the EXI interface, as used on all their cranks now.
Ricks
Posted : 19/04/2014 10:41 pm
RaceFace are correct, both exist.
I have an older set of Evolve's on my Soul which have a rather neat self extracting setup where you take one bolt out then use a bigger key to turn the revealed keyhole to self extract, and I have a newer set on my Chameloen (that seem ts be reasonably recent oem stock like you might find on a recent Orange) that use a normal crank puller.
You'll need to take a look, I'm afraid...
Posted : 19/04/2014 11:25 pm
 JoeG
My Evolves bought Dec 2012 need a crank puller.
The right tool is a puller that works with ISIS/Octalink. Or you can use a square taper puller along with something like this
Edit - or a couple of coins or washers.
Posted : 20/04/2014 4:56 am
Both my 2010 evolve and 2011 respond need the pellet as above I think the self extracting version got phased out before 2010
Posted : 20/04/2014 2:23 pm
You can use 3 x 1 cent euro coins glued together, fits perfectly
Posted : 20/04/2014 4:40 pm
Bought an ISIS puller. I don't mind having extra tools, and it's not bonkers money.
Cheers chaps.
Posted : 20/04/2014 5:44 pm
