Raceface Aeffect Dr...
[Closed] Raceface Aeffect Dropper air valve...
6 Users
Hi Chaps,
I've got a 2019 Aeffect Dropper, and I can't find the air valve. I'd expect it under the saddle, but it looks like a nylock nut, rather than a valve. Which looks suspiciously like it's a footnut.
Anyone topped up the air in theirs?
Ricks
Posted : 23/07/2019 12:38 am
Ok probably talking out of my rear here but I thought someone on here said there is no valve on the RF?
That said, hopefully I'm wrong!
Posted : 23/07/2019 3:18 am
Pretty sure they are under the clamp assembly as i've had to top a few up in the past. If you check on the side, I think you'll find a recommended max psi setting as confirmation.
Posted : 23/07/2019 7:04 am
Schrader valve under the clamp, covered by a rubber/plastic cap. The Turbine version needs a 10mm socket to remove IIRC, haven't tried with my Aeffect.
Posted : 23/07/2019 7:27 am
Certainly the case on my 2018
Posted : 23/07/2019 8:04 am
Mine doesn't have the rubber cap and Schrader valve, it's what appears to be a nylock nut. It's very odd! I've seen the videos and photos of the pre-2019 and it looks different to mine.
Posted : 23/07/2019 8:31 am
I'd be surprised if the valve wasn't underneath it. All these posts need some way of pressurising and depressurising.
Posted : 23/07/2019 8:45 am
Well, Raceface support replied to my email. They said I'd better send it to them for a service.
I've had it a month.
All I want to do is top up the air!
Posted : 27/07/2019 8:16 pm
Ricks, Did you send it in? Did it help with return speed? I’ve got the same post and it’s slow.
Posted : 23/02/2020 3:35 pm
