Race lightening my ...
[Closed] Race lightening my Pipedream Skookum .... worth it?
8 Users
So I'm going to give a few races a go this autumn & winter.
I'm happy to work within my own fitness limitations and I will only be racing me.
I have a couple of bikes that I could use - all equally unsuitable for a variety of reasons.
That said my Skookum is probably the least "trailsy" and a posible starting ground.
The only change to the bike from this pic is some Magura Louise carbon brakes:
Its currently a dedicated SS with a wonderfully heavy duty Hope SS rear hub that would need swapping out and some [i]for the look[/i] wire bead skinwalls.
Clearly wheels would need addressing and the addition of 1xX gears but for the want of a better expression am I polishing a turd starting with a heavyish steel frame?
I do think I would struggle to get close to sub 25lb 😳
I appreciate that anything I buy (possible exception the front wheel) could be used on another racier build if the concept works and I could swap stuff over to a new frame.
So where would you start?
Clean sheet of paper or work with what I have.
Kit recommendations would be welcome especially around wheels.
Cheers,
Mark
Posted : 31/07/2015 9:33 am
The only real benefit to upgrading that will be in your head, if you can get round that then you've saved ££££.
If you need it to feel lighter/faster then tyres and rims are no. 1. Saving weight elsewhere gets expensive and is less noticeable.
Posted : 31/07/2015 9:38 am
FWIW I race on a steel frame as well and that comes out as around 10.5kg (~23lbs in archaic units) and I reckon I can get it below 10kg with some careful purchases.
Wheels is definitely a good place to start, crests on your hub of choice is always a good bet. Finishing kit can be surprisingly heavy, mt zoom and kcnc are a good place to start.
Posted : 31/07/2015 9:49 am
@everyone ..... got a pic for some inspiration 😉
Posted : 31/07/2015 9:57 am
FWIW any racing I do is on a 4lb steel HT frame with 2005 Revelations. I don't think it's very light, not weighed it in a while.
Posted : 31/07/2015 10:00 am
 DT78
Hub of your choice on light bicycle rims, schwalbe careful Colin's, Mr zoom carbon bar, swap your saddle and post out for I beam version. Make a spreadsheet with all the parts and weights, same with replacements £1 per gram seems to be seen as good value !
Posted : 31/07/2015 10:02 am
Don't get me wrong I've done the weight weenie thing before and it wasn't for me:
[URL= http://i225.photobucket.com/albums/dd279/letmetalktomark/IMGP2928_zpsc90fd467.jp g" target="_blank">http://i225.photobucket.com/albums/dd279/letmetalktomark/IMGP2928_zpsc90fd467.jp g"/> [/IMG][/URL]
This got down to about 17lbs IIRC and was horrible to ride!
Sensibly light is what I'm look for I guess.
Anyone have any thoughts on Crests Vs Hopes Tech XC rim?
Posted : 31/07/2015 10:07 am
Neither, Light Bicycle carbon rims are lighter and stiffer, which is more important on a 29er wheelset.
Posted : 31/07/2015 10:19 am
One racey steel hardtail coming right up!
[url= https://farm1.staticflickr.com/366/18718163275_bd6dfc2b8f_z.jp g" target="_blank">https://farm1.staticflickr.com/366/18718163275_bd6dfc2b8f_z.jp g"/> [/img][/url][url= https://flic.kr/p/uw4tP2 ]WP_20150611_006[/url] by [url= https://www.flickr.com/photos/131713376@N04/ ]Nathan Peel[/url], on Flickr
Pictures a bit rubbish, but you get the idea. Next upgrades for this will probably be some new forks (thinking 26" fox's, not opposed to something a bit different like the formula 33s though) carbon Ritchey post and some race wheels (light bicycle rims on something like Mack hubs I think.) Might even change to 11s XTR at some point as well.
For the level you'll be starting at (Sport category racing, mid-field with hopes of more?) I'd add some gears (the 6 or 7 you can cram on a Hope SS hub is probably enough) and leave it at that. It's not a race bike but it'll do as well as the lump on top can. If you enjoy it, start getting top 5 results, decide you want to keep racing next year and so on then I'd start from scratch with a different bike in the spring.
Posted : 31/07/2015 10:23 am
 DT78
Scott scales will probably start being discounted about now, seem to remember I bought mine in sept for a decent price. Probably one of the best off the peg racers you can get at whatever you budget is. Flog the current bike.
Posted : 31/07/2015 10:38 am
I got on the podium at the nationals (sport) and won a regional series and champs (vets) last year on a bike not much lighter than that last year.
You'll be fine.
Posted : 31/07/2015 10:39 am
Of course you can. You're giving away 3lbs to the lightest frame, but you could go sub-18lbs if you wanted.
Posted : 31/07/2015 11:37 am
I'm not sure how affordable that would be though!
Posted : 31/07/2015 11:41 am
