quick solaris hope ...
[Closed] quick solaris hope headset question
4 Users
I'm confused - headsets have got so complicated!
For a solaris with a tapered fork , I think I need a bottom Hope 'H' cup for 1.5 steer, and a top Hope '2' cup for 1 1/8 steerer?
Cotic site says: 44mm standard head tube designed with external bottom cup for taper steerer compatibility and zero stack top cup for minimal stack height
Thanks for any help...
Posted : 25/11/2014 4:39 pm
Spot on.
For your tapered fork that is all you need (but don't forget to get a start nut and top cap or a head doctor as they don't come with pick and mix).
If you ever want to switch to a straight fork then you need the crown reducer HS136
Posted : 25/11/2014 4:56 pm
 jimw
Yes, that is correct I believe. See this diagram, second from left.
/p>
Edit:
Too slow!
Posted : 25/11/2014 4:57 pm
thanks both!
Posted : 25/11/2014 5:16 pm
Yup, 2H
Posted : 26/11/2014 9:47 am
