I have a FSA Pig Pro headset, which has been on the bike about 1000ish miles, and it has started to feel a bit rough.
Am i right in thinking all i need to do is pop the upper/lower bearings out and replace as the cups should be fine, or is it best to just replace the whole lot..which would cost me about £20 + fitting?
Also if i can just replace the bearings i assume they will have model #s on them to be able to source similar?
Cheers all 🙂
Posted : 31/05/2009 8:14 pm
Yep, just replace the bearings and you should be fime.
Posted : 31/05/2009 8:16 pm
