Quick-fit mudguards...
[Closed] Quick-fit mudguards for Gravel bikes
10 Users
I've come to the conclusion that I need some mudguards for my commuter / gravel bike. In the winter I run a skinny(ish) 34c tyre setup and full guards which is fine, but in the summer (April - Oct ish) I like to run fatter 40c front / 38c rear tyres and go off road whenever I can.
However, when it rains I have a problem. I want to keep riding to work but I HATE the wet bum / feet you get when riding in rain without guards. So I need some clip-on guards I think. But I can't seem to find any that will fit such large tyres. I don't need full coverage, but ideally I want more than just an ass-saver type thing.
Any suggestions?
Posted : 28/07/2019 10:21 pm
New bike time!
Posted : 28/07/2019 10:27 pm
Raceblade Pro XL. They're not perfect but they're just wide enough to work with 40c tyres.
Posted : 28/07/2019 10:37 pm
SKS Speedrocker - better coverage than raceblades and can fit in a couple of minutes.
I run with 38mm G-one Speeds no problem.
S
Posted : 28/07/2019 11:43 pm
SKS Speedrocker. Ive binned the Raceblade now
Posted : 29/07/2019 8:13 am
Speedrocker 3rd’d fit quick and easy, stable and rattle free so far. Just be aware of toe overlap on the front with a big guard and big tyre.
Posted : 29/07/2019 10:10 am
Zefal trail if you don't want to spend speedrocker money...
https://www.tredz.co.uk/.Zefal-Trail-Hybrid-City-Mudguard-Set_42211.htm
I had to cut the rear clip to fit, so I leave it cable tied on. The front can be slid off the mount easily or removed with simple allen key.
Posted : 29/07/2019 10:16 am
Sslight hijack, sorry, is there a narrower version of the Speedrocker?
They look perfect for the wife's roadbike with no clearance under the stays, but tyres are only 28c.
Posted : 29/07/2019 11:35 am
I use these once the weather improves -
https://www.chainreactioncycles.com/zefal-classic-mudguard-set/rp-prod128256
In the proper winter the SKSs go on, but I hate mudguards, so remove them and fit the brackets for a set of the Zefals. When rain is forecast I jam them on. Leave them off the rest of the time.
I love the fact I have £7 mudguards on a £4K Ti bike 🙂
Posted : 29/07/2019 12:34 pm
[I] fit the brackets for a set of the Zefals. When rain is forecast I jam them on. Leave them off the rest of the time.
That sounds like it could work - do they just jam onto those metal L-shaped brackets then? They sounds suitably quick to attach...?
Posted : 29/07/2019 2:39 pm
They do indeed, takes seconds. I do have to zip tie (removeable type) the front of the rear mudguard to my seat tube to stop it rubbing the tyre, but thats as complicated as it gets.
BTW - jimdoubleyou's link is to the actual gravel bike sized ones.
Oh, I also had to flatten the rear bracket as my Tripster only has an "underneath" hole. Pretty simple though.
Posted : 29/07/2019 3:11 pm
Merlin have a small discount on Speedrockers.
Posted : 29/07/2019 3:44 pm
