Quick Deore chainri...
[Closed] Quick Deore chainring Q...
2 Users
Whats the difference between M510 and M532 chainring?
http://www.chainreactioncycles.com/Models.aspx?ModelID=5699
http://www.chainreactioncycles.com/Models.aspx?ModelID=38192
are the bolt holes different? Needs to fit Raceface cranks
Thankyou 🙂
Posted : 02/05/2013 4:44 pm
Guessing, but I'd suggest the inner tab might be longer on one than the other, as I've had to file Deore rings to fit before now. Just bought a m532 that fitted directly onto a m760 crankset, if that helps any, but a quick session with a file might be necessary for your RF chainset (I done his quite a few time & had no failures due to it). Oh and there might be some small trickle down tech changes on the pins & ramps, doubt its ground breaking though
Posted : 02/05/2013 5:27 pm
