Quick bottom bracke...
[Closed] Quick bottom bracket question - Shimano cup size/tool changed?
7 Users
Narrowed down the noise to the BB (I think), it's a SM-BB70, old model XT?
Looking at current XT, MT800, the cups look smaller overall. Is the tool the same? If not, is it worth changing to new standard or should I buy a third party version from Uberbike or somebody?
Posted : 13/09/2021 7:25 pm
it is a different size but when I bought a new BB I got the adapter with it to fit the old tool to the new cups
Posted : 13/09/2021 7:33 pm
As above, the later road and MTB higher end bottom brackets are supplied with a plastic adapter that fits inside the original tool - if from a reputable dealer!
Posted : 13/09/2021 7:47 pm
Shimano now have 3 "standard" hollow tech BB cup sizes;
16 notch 44mm Older hollowtech
16 notch 41mm "New" Ultegra 6800, MT-800
16 notch 39mm "New" XTR, Dura Ace
Some of them also fit mid drive lockrings, some STEPS etc
Its annoying.
Posted : 13/09/2021 10:50 pm
 Tim
You get an adaptor with them so it doesn't really matter
Posted : 14/09/2021 7:19 am
Watch out if you are hamfisted and the bottom bracket is very tight in the frame as they are made of plastic and can split. Yes I am hamfisted.
Posted : 14/09/2021 8:13 am
Was looking for a bottom bracket myself a couple of weeks back looked at the XT 8000 but most didn't supply the adaptor you had to buy separate (£5 for a piece of plastic) so just got one from Uberbike & you can replace the bearings...
Posted : 14/09/2021 10:04 am
