QR/15mm Thru axle c...
[Closed] QR/15mm Thru axle compatability
5 Users
I'm sure this has been done before, but I need to ask...
I am buying a disc CX bike (with a QR fork) and a MTB (with 15mm thru-axle fork). Is there any way I could use the same fron wheel on both without installing different hub adapters every time I wanted to switch over?
I know you can convert hubs like DT Swiss, but is there any kity which allows say QR use in a 15mm fork?
Posted : 23/05/2015 11:59 am
The hope end caps are quick to swap, using QR in a 15mm fork would be a big step back.
Posted : 23/05/2015 12:04 pm
Easy. 15mm MTB wheel becomes QR CX wheel.
Posted : 23/05/2015 12:37 pm
If you have QR15mm front wheel than [url= http://www.chainreactioncycles.com/mobile/nukeproof-conversion-kit-15mm-to-qr/rp-prod80192 ]this[/url] should do the job well. Works for me 😉
Posted : 23/05/2015 12:40 pm
With one of those, would the wheel still fit in the 15mm forks as well as the QR forks?
Posted : 23/05/2015 1:14 pm
You need QR15mm wheel so it fits with your forks. You'd need an adapter to use with your QR15 wheel if you decide to fit it to standard/9mm dropout forks.
Posted : 23/05/2015 2:01 pm
Sorry for being slow - so then would I be able to then swap it back and forth between forks without f'cking with adapters and what not?
Posted : 23/05/2015 2:03 pm
I have a Nukeproof version of the adapter in jameso's post above that I use in a set of DT Swiss wheels on my 9mm Reba forks , it literally just slides into the 15mm hub and fixes into the fork with a standard q/r skewer. Got mine from CRC but plenty of other places sell the same thing.
Posted : 23/05/2015 3:02 pm
