QR 29" Rear Wh...
[Closed] QR 29" Rear Wheel for less than £100 ?
7 Users
The rear wheel on my Spec Crave 2015 has broke. The bike mechanic says it's the spindle causing the issues and that I need a replacement. All wheels I've looked at so far are expensive. I've just spent £200 on a Rear wheel for my FS and don't want to spend that much again. Is it possible to get anything worthwhile for less than £100 or will it just break in no time ? It is mainly for XC use.
Posted : 15/08/2017 12:22 am
On One had a deal on recently but can't remember if the hub was QR, or if it was convertible?
Might be worth a look.
Posted : 15/08/2017 12:40 am
 cp
A pair for a hundred quid:-
http://www.planetx.co.uk/i/q/WBI25EGRS/wtb-st-i25-tcs-rim-on-el-guapo-rattlesnake-hubs
Posted : 15/08/2017 1:21 am
What's actually broken on your current wheel
Posted : 15/08/2017 5:52 am
Is this the same mechanic that tells you to replace everything, even if it's fixable? As above, what is actually wrong with it?
Posted : 15/08/2017 6:07 am
I think the Freehub is 11 Speed so it wouldn't be compatible with my 10 Speed Drive train ?
Posted : 15/08/2017 9:55 am
He mentioned the Spindle is knackered. How it effects the riding ? It makes the cassette move around which makes the gears perform horribly. Plus it makes a lot of noise when coasting. I don't know anything about it other than that.
Posted : 15/08/2017 9:57 am
what's the spindle?
there is an axle and a qr skewer.
 cp
it will work fine, the mounting splines on mtb 10 and 11 speed are the same length.
Road 11 speed is a bit longer but the hub usually comes with a spacer to run road 10.
Posted : 15/08/2017 9:59 am
Not sure myself. I'm only going off what he was telling me. I'll ask next time I see him, in a few days.
Might be the freewheel is faulty?
Anyway, as said your cassette will fit the above wheel fine.
Posted : 15/08/2017 10:35 am
It turns out the front wheel won't fit as mine isn't a 15mm through bolt its more like the quick release like the rear. Is there a way to convert it ? I know I'm only after a Rear Wheel replacement but I don't want to be buying a Front wheel that's not compatible.
Posted : 15/08/2017 12:46 pm
Possibly these - 9mm QR front?
https://www.planetx.co.uk/i/q/WSELSEC/replacement-end-cap-pair-for-el-guapo---selcof-hub
Would want to check with them first.
Posted : 15/08/2017 1:29 pm
 cp
yeah it's those - in 9mm qr front
Posted : 15/08/2017 1:58 pm
Thanks. A set of those has been ordered.
Posted : 21/08/2017 11:23 pm
