My bike fell over this morning and hit the rear mech. Gears are now on the swazz so I think the mech hangar has done it's job. I'm going to try bending it straight but I will buy a new mech hangar anyway. I bought the bike second hand and I'm not 100% sure which version it is. It looks like they do difference hangars for different versions so how do I tell which one it is or should I just take the mech off and see what it looks like?
Take a look at the chainstay behind the crank and the dropouts
If they are flat bar looking like in the link below then its a V1 or V2 model
If both are a more normal tube shape then its a v3 or V4, the V4 is the newest version and uses a UDH hanger and was only released last year
Also the v1 and v2 had a 31.6mm seatpost and the v3 and v4 use a 27.2mm one iirc
Thanks for that. Very helpful.
Just slightly puzzled that you say if it’s like the one in the link it’s a V1 or V2 but that ad says it’s a V3?🤔
The ad wording is wrong, that’s deffo a V1 or V2 frame
i had a V3 and it had normal dropouts and chain stays along with a 27.2mm seat tube
Ah, that explains it! Thanks.
