Putting a 140mm tra...
[Closed] Putting a 140mm travel fork on my 2016 Tallboy?
5 Users
I've been told it will slow down the handling due to the slacker head angle, would it be noticeable? If so in what way? I know this is a xc bike but how would the bigger travel forks alter it?
Thanks.
Posted : 29/01/2016 4:23 pm
It will slow it down a bit. If you get a fork with 51mm offset, that will help things a bit. I run a 120 sid and 140 pike on my 29er, no probs.
May feel like it wanders more on climbs but should be more stable on the downs.
Posted : 30/01/2016 6:23 am
a ran both 140mm 34's and 140mm Pikes on mine at one point or another, very capable, front end was quite high for me (5'6") hence the Syntax stem when i switched to Pikes,
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/CCA59EEF-9013-45A6-AA8A-9F79CEBBB1D1-5241-00000201EBBF04BB.jp g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/CCA59EEF-9013-45A6-AA8A-9F79CEBBB1D1-5241-00000201EBBF04BB.jp g"/> [/IMG][/URL]
[URL= http://i1272.photobucket.com/albums/y394/dansipods2/487444_10153971824840506_942466681_n_zps8ed9ce86.jp g" target="_blank">http://i1272.photobucket.com/albums/y394/dansipods2/487444_10153971824840506_942466681_n_zps8ed9ce86.jp g"/> [/IMG][/URL]
Posted : 30/01/2016 7:27 am
I've been looking at rockshox
rct3 140 mm, but I see they do a 130mm, this might be a compromise, would I still need 51mm offset with the 130mm? I'm
6 ft 1 if that helps any.
Posted : 30/01/2016 9:08 am
I'm running 150mm pikes on mine and don't really notice anything detrimental.. 😀
Posted : 30/01/2016 10:11 am
Like that dirty, very nice....
Posted : 30/01/2016 12:10 pm
