Putting 700x25 tube...
[Closed] Putting 700x25 tubes into 700x32 tyres....
9 Users
Will they go pop!!?
Posted : 13/09/2011 10:26 am
not in my non-rad riding experience*
*bike riding is a hazardous pastime and tyre/tube selection is a personal safety choice, please retain this forum
edit as in done loads of times and used offroad but i'm a lightweight and possibly a coward
Posted : 13/09/2011 10:40 am
I bought slightly undersized tubes for my 28c tyres and they were fine. Rubber's stretchy 🙂
Posted : 13/09/2011 10:41 am
Might do, but 7mm isn't exactly a lot.
I've got a 1.75" conti touring tube in the rear wheel on my SS with a 2.1" racing Ralph on there, hasn't gone bang yet
Posted : 13/09/2011 10:43 am
they shouldn't go pop, but they will puncture VERY easily if you ride offroad.
Posted : 13/09/2011 10:44 am
I managed to squeeze a 700x32 tube into a 700x23 tyre the other day. I suspect I did a stupid. I have the proper size tubes now, but no real inclination to fix it until something goes wrong.
Posted : 13/09/2011 10:49 am
I tried 700x45 in 700x65 tyres on advice from the bike shop who said it would be fine, and they were a definite pop every time. So at that range it is a really bad idea. I'd guess 7mm will probably be okay, but they are going to be quite stretched.
My top tip is don't accept the advice of a bike shop who might tell you they are okay just to sell a tube!
Posted : 13/09/2011 10:50 am
Shouldn't go pop. 700x25 tubes are designed for 100psi plus pressures, you'll only likely be running 60 - 80psi or so in a 32 tyre. Tyre beads may not sit so tight though.
Had one go pop for this reason on a recent cycle tour. Luggage off, wheel out, changed tube, pumped it up....pop. Start all over again.
I hadn't noticed I'd taken 700x25 tubes instead of 32's. Tube was a brand new conti one, had an inch split along the seam. Popped at about 80psi.
Posted : 13/09/2011 10:51 am
Well, just been out ridin' on 'em (on the hybrid), didn't go pop but did get a puncture. Dunno if it was caused by the tubes though.
Posted : 13/09/2011 1:48 pm
Until I put big tyres on again at the weekend, I've been running 23 tubes in 28 tyres for ages with no punctures. Commuted on them and taken them on off-road stuff too, with no problems.
Posted : 13/09/2011 2:25 pm
