I have a Race Rocket MT and can see brackets online - however, I don't think it will clear the huge downtube on my eeb.
Any solutions for such scenarios?
Trying to get tools off my person (back/hip packs) and onto the bike for short rides
3d printing.
Duct tape?
Srsly tho, Zefal Doodads have worked for me for years. there are a few versions about.
You can rotate them in the bolt holes. Should accommodate the down tube.
Not sure how you mean? This is the Topeak bracket
I just put them on the non-drive side of the seat tube. Not had a problem with cranks/calves clearing the pump or have you got some limitation with suspension going on and only having the downtube?
Aha, found the alternative solution, I knew I had seen something like it.
https://www.sjscycles.co.uk/bottles-cages/wolf-tooth-brad-bottle-shift/
My downtube is 3-4" wide - the tab holes on the bracket simply (probably) won't reach the bosses *edit - misread your post. No bosses on the seat tube, albeit I could use some add on's. Everything gets crappy on the ST though
[url= https://live.staticflickr.com/65535/53132377461_95a0bcdd13_b.jp g" target="_blank">https://live.staticflickr.com/65535/53132377461_95a0bcdd13_b.jp g"/> [/img][/url][url= https://www.flickr.com/gp/85252658@N05/8gUQ82P9k2 ]20230821_184229[/url] by [url= https://www.flickr.com/photos/85252658@N05/ ]davetheblade[/url], on Flickr
Ooh, that'll probably do it. Nice one 🙂
Ah mine have. A curve in the opposite plane so for on almost any tube surface. They slide out to accommodate bigger tubes.
The thing i never knew i needed. Definitely getting those very soon!
The zefal doodads, that is!
