PSA - SRAM X1 Eagle...
[Closed] PSA - SRAM X1 Eagle Cranks
32 Users
SRAM X1 Eagle Boost Cranks w/Direct Mount Chainring. Fits the GXP bottom bracket, various lengths and chainring sizes. £69.99 from Wiggle.
I know it’s not the new DUB size - but a bit of a bargain considering it’s down from over £200 and has carbon arms. I’ve ordered a set - as I could do with a boost-compatible ring and a pair of crank arms, for another bike I’m renovating.
https://www.wiggle.co.uk/sram-x1-eagle-gxp-boost-crankset/?utm_source=order-placed-sg01-gb&utm_medium=email&utm_campaign=orders&utm_content=product
Posted : 03/04/2019 5:51 pm
The listing is all over the place; it's not a photo of an eagle chainring and the Product Data section refers to 11 speed, but the rest of it says eagle 12 speed 🧐
Posted : 03/04/2019 5:58 pm
^^ I did notice that. It’s not unique in being a bit of a shite description! 😉
If it turns up and isn’t 12 speed or Eagle - it will be going back. I can’t see Wiggle arguing and refusing free return postage. I took a screenshot in case! 🙂
Posted : 03/04/2019 6:12 pm
I just had a look st this and was looking for a chain to go with it. SRAM PC-X01 Eagle 12 Speed Chain is listed in the product description as 9 speed ! I dare say these are all just silly errors and it is all 12 speed really, but it doesn’t exactly inspire confidence and I can’t be bothered with the hassle of returning stuff, so I think I’ll wait.
Posted : 03/04/2019 6:18 pm
I’ll report back. If off work at the moment and have time on my hands.
Posted : 03/04/2019 6:20 pm
The XX1 Eagle cranks are also very much reduced. £156.99 - again in GXP. Only 170mm and 32T.
https://www.wiggle.co.uk/sram-xx1-eagle-gxp-crankset/
It also has the same product data errors...
Posted : 03/04/2019 6:26 pm
There was a psa about this a few days back.
Don't forget, use a new email addy and you get £10 off, making them £59.99😁
Posted : 03/04/2019 6:51 pm
Have a look at the other thread they are carbon eagle X1 with a 3mm offset chain ring.
We had two sets delivered yesterday
https://singletrackmag.com/forum/topic/sram-next-rally-carbon-crank-wobbly-insert/
Posted : 03/04/2019 6:59 pm
Doh! All, apologies for the repeat post.
Posted : 03/04/2019 7:08 pm
As long as we all get bargains from PSAs then it's not a problem how many times it's repeated.
Posted : 03/04/2019 7:20 pm
Thanks both. I think I might have actually replied to a previous PSA thread about these now I come to think of it (doh). It’s all good though and I’ve finally ordered them so maybe I can make a more us3ful contribution to the next thread 🙂
Posted : 03/04/2019 8:20 pm
^^ Not at all! I took it as it was intended - you were being helpful.
Posted : 03/04/2019 8:23 pm
Must. Not. Order. 😟
Posted : 03/04/2019 8:42 pm
Posted : 03/04/2019 8:43 pm
Totally ordered.
Posted : 03/04/2019 8:45 pm
Am I right in thinking it's just the offset on the ring that makes these boost? (3mm versus 6mm on old stuff)
Posted : 03/04/2019 8:51 pm
Yes
Posted : 03/04/2019 8:53 pm
Received dispatch notification from Wiggle, I’ll feed back when they arrive.
Posted : 04/04/2019 12:24 pm
Thanks for the PSA just ordered some to replace my XO cranks, nothing wrong with the XO's but the colour scheme on these match much better.
Posted : 04/04/2019 2:32 pm
Ordered...I have no need for these either!
Posted : 04/04/2019 2:52 pm
so, these are only 'boost' because of the chainring offset?
So i could replace a normal set of shimano 24mm spindle cranks with these and just put a 10sp NW chainring on?
Posted : 04/04/2019 5:26 pm
Can't see it on Wiggle, are these 30mm or 24mm axle? Ta.
Posted : 04/04/2019 5:31 pm
24mm and using the GXP standard bottom bracket that is easy to get hold of - or Hope do adaptors for their own external
BB’s.
Posted : 04/04/2019 5:50 pm
it says gpx, so i think thats 24mm
Posted : 04/04/2019 6:48 pm
As long as the chainring has the SRAM mount you can use 6mm o/s, 3mm o/s that it comes with or even 0 o/s to get the best chain line. You can then sell on the boost chainring to recoup some of the cost.
Posted : 04/04/2019 7:40 pm
Cheers.
Ordered.
Edit - Amazed by the price of the SRAM chainrings...
Posted : 05/04/2019 1:27 pm
These arrived today:
Posted : 05/04/2019 2:04 pm
Mine arrived today, lovely! Going straight in the spares box ha ha! Weighed in at 538g so very reasonable indeed.
Posted : 05/04/2019 3:57 pm
Tempted by there but a non boost chainring is nearly the same price again 😐
Posted : 05/04/2019 4:05 pm
Edit – Amazed by the price of the SRAM chainrings…
Yes, I fancied trying a 30T chainring on my GX Eagle setup this year, but ended up buying these (with 30T) instead as I was almost getting the carbon cranks for free 🙂
Posted : 05/04/2019 4:12 pm
Boost & non-boost X-Sync NW chainrings are available from other 3rd party suppliers.
Switch system from One Up looks like an attractive solution.
Absolute Black
Blackspire
Superstar
etc.
Posted : 05/04/2019 4:48 pm
Maybe it’s taking the point out of buying carbon cranks for weight saving, but steel sram direct mount chainrings aren’t expensive at all, and they last ages!
https://www.tredz.co.uk/.SRAM-X-Sync-2-Steel-Direct-Mount-Chain-Ring_201228.htm
Posted : 05/04/2019 4:49 pm
Mine have arrived and look good. Not quite as as nice as my original 11spd XX1’s - but very stealthy!
Posted : 05/04/2019 5:44 pm
I do not need them,
I do not need them,
I do not need them,
I do not need them,
I do not need them,
I do not need them,
I do not need them.
Posted : 05/04/2019 6:23 pm
That is a proper bargain!
Do I want them, yes.
Do I need them, no.
Am I going to get them, nope, not a chance.
Posted : 05/04/2019 6:35 pm
Poops, perfect upgrade for the crappy 30mm cranks on the Jeffsy. Can fit a 24mm bb (with adapters). Problem solved
Posted : 05/04/2019 7:03 pm
No need to worry prices have gone up from £70to130 and 159 to £289
Posted : 05/04/2019 7:51 pm
russyh
Subscriber
That's exactly what I was thinking.lol
I'm actually pleased they have gone back up in price now! No temptation.lol
Posted : 05/04/2019 8:08 pm
EDIT: Still showing as £69 for me?😟
Posted : 05/04/2019 8:09 pm
Mine arrived today, I ended up taking them through to my accessort-obsessed colleague to show her how shiny and carbony they are and saying "this is how I feel every time you show me a new handbag"
Posted : 05/04/2019 9:35 pm
I’m confused @poopscoop they had definately increased in price in my basket, the xx1 have gone up from £260, but now the x01 xsync are £129.99 https://www.wiggle.co.uk/sram-x01-gxp-x-sync-11spd-crankset/
And the £69.99 are still £69.99
GX1200 £44.99
https://www.wiggle.co.uk/sram-gx-1200-chainset-11-speed-gxp/
Posted : 05/04/2019 9:46 pm
Damn it!
If they are still at this price in a day or 2 I might relent! Trouble is... I'll need a new oval ring (I'm a convert) and a new BB adapter or even BB.....
So my bargain starts getting expensive!
But it's stealthy, 24mm.... and CARBON,CARBON! Gahhhhh!
Posted : 05/04/2019 10:06 pm
Well your get decent money for the Sram ring if you insist on oval, which I’m running at minute and frankly I can’t see any benefit...only chaindrops bizarrely. BB didn’t you need to change yours anyway? Just buy the cranks and keep in stock until you need to buy a new Bb again, which even if your current one is new is likely only a couple of weeks away lol
Posted : 05/04/2019 10:11 pm
365 day return or sell them on eBay if they don’t work out,
I’m holding out too I’d need a new bb and I like my purple raceface cinch
russyh
Subscriber
Well your get decent money for the Sram ring if you insist on oval, which I’m running at minute and frankly I can’t see any benefit…only chaindrops bizarrely. BB didn’t you need to change yours anyway? Just buy the cranks and keep in stock until you need to buy a new Bb again, which even if your current one is new is likely only a couple of weeks away lol
BB alright for the moment but no way I'm going to press a new unserviceable Hope BB into a carbon frame on a semi regular basis. Putting in the Hope one made me sweat enough.lol
Hmmmm... I see my BB41 can run a GXP crank with a shim.... So I could run the bb41 into the ground using the X1 cranks, then go for a serviceable bb when that one dies...
As you said,I can sell the oem ring easy enough, also the Turbine cranks for that matter. Oh,I like the oval rings as they dramatically reduce knee pain for me. Not really bothered about claimed "efficiencies" same as you.
Posted : 05/04/2019 11:15 pm
Well, thanks a lot guys! NOT!!
Just ordered the crank for £59.... Didn't think to order the shims.... But I won't use the crank for a while anyway.
Obviously justified this to myself by saying I'll need a 24mm crank soonish anyway.... and that I'll obviously pedal faster on carbon cranks....
Will be selling the oem 32t ring though.
Ahem.... 😊
Posted : 05/04/2019 11:37 pm
Blimey.... Don't think I'll bother with a genuine Eagle oval, too expensive.... I'll be fitting a Works/AB oval I think.
I've been running an AB ring for ages on my gx eagle setup anyway and they are great.👍
Posted : 05/04/2019 11:48 pm
Still £69 when I looked too.
Posted : 06/04/2019 4:31 am
Good call poops, I’ll bet the upgrade is almost cost neutral by the time you sell you turbines!
Posted : 06/04/2019 6:58 am
Silly question, but isn't SRAM x1 11 speed only? I though eagle was only nx, gx, x01 and xx1?
Posted : 06/04/2019 9:21 am
Can you get an adapter for race face bb9 to gxp?
Posted : 06/04/2019 9:48 am
russyh
Subscriber
I think you are right mate. I'm excluding the new BB cost as I will need that soon one way or another anyway.
Quiet a bit of choice for the oval ring these days.... Though I'll probably pay the extra for the AB one as they are so pretty.lol
Posted : 06/04/2019 3:36 pm
Okay - I’ve ordered some too (see my post on wobbly race face next rally cranks.....)
So what actually is gxp? Is it just a 24mm b/b? I have a Hope pf30 currently - I think you can get an adapter for that? Or could I use a 24mm hope b/b?
Posted : 06/04/2019 3:46 pm
peter1979
Member
Silly question, but isn’t SRAM x1 11 speed only? I though eagle was only nx, gx, x01 and xx1?
In truth I'm not sure either. Someone mentioned these are oem? Perhaps that's why.
As long as they are carbon and have an eagle ring on I'll be happy.👍
Posted : 06/04/2019 3:47 pm
@Charlie
I think you can use an adapter. That's my plan till I have to change the BB anyway.
Posted : 06/04/2019 3:49 pm
 Bolt
Mine didn't come with a wavy washer, should one be in the box?
Posted : 06/04/2019 3:52 pm
Wasn't going to bother, then I saw people selling them on ebay for £160 and thought nothing to loose either way. I was really after 170 32 tooth but ended up with 175 30 tooth, but cant complain for the price of a chainring.
I either need an adaptor for a raceface bb90 to gxp or a non boost chainring depending on what bike they go on.
Cheers for the PSA OP
Posted : 06/04/2019 4:27 pm
Bolt
Subscriber
Mine didn’t come with a wavy washer, should one be in the box?
Good question, anyone?
Posted : 06/04/2019 4:38 pm
You dontnuse wavy washer on GXp I don’t believe, my descendants don’t. The smaller non drive side axle fits into the bb so no need to preload. Like I say my current GXP cranks with hope bb have no way of preloading, have no play and are frankly superb
Posted : 06/04/2019 6:07 pm
The wavy washer is to hold the DS seal against the bearing. You wouldn't need one with a Hope BB as the seal can't move anyway, but for a lippy contact type seal you need one. One came with my Wheels mfg. bottom bracket (a gxp specific one) as they have that type of seal, it also came with some washers in case the gap was too big for the wavy washer to bridge.
You can get O-rings off ebay etc. to do the same job apparently.
Posted : 06/04/2019 7:39 pm
GXP is 24mm then tapers to 22mm on the opposite side so you need a GXP bottom bracket.
A standard Shimano 24mm will not work.
Posted : 06/04/2019 7:43 pm
A standard 24mm bb will work with spacers eg the ones for Hope. I used to use my SRAM cranks with a Hope BB and Hope spacers on the NDS, it worked fine and didn't need a wavy washer. And of course, the DS cups/bearings are the same whichever, if you like to pick 'n mix.
Posted : 06/04/2019 9:07 pm
Greyspoke & dhrider have the BB compatibility sorted for external threaded BB’s.
As for the X1 Eagle 12 speed question, these look like OEM products - as they come with no aftermarket packaging.
I imagine these are fitted from the SRAM factory with Eagle rings for a production bike.
Posted : 06/04/2019 9:49 pm
I think the wavy washer thing is the same for PF92 types, my gxp cranks are currently in a frame with a PF92 shell. The difference from external threaded cups is the way the cups fit in the frame and the frame bb shell. The bearings are the same type and the same distance apart and most bb manufacturers probably use the same seals as well.
Posted : 07/04/2019 7:43 am
Okay - I currently have a hope pf30 bottom bracket. Can this be adapted for gxp or do I need to get a hope 24mm b/b for the hope adapter to work?
Hope that made sense!!
Posted : 07/04/2019 9:59 am
You need a Hope 24 and Hope GXP adaptor kit. That’s what I use.
Posted : 07/04/2019 10:07 am
I dunno charlie I have never used pf30. But there is this:
https://wheelsmfg.com/products/bb-crank-adapters/bb-pf30-universal-adapter-for-22-24mm-spindle-cranks-sram-truvativ.html
Posted : 07/04/2019 10:09 am
^^there you are then.
Posted : 07/04/2019 10:10 am
Give Hopetech a ring and they will tell you which parts you need to make it fit.
Posted : 07/04/2019 10:12 am
Never seen that before greyspoke - that looks like it would work fine.
Posted : 07/04/2019 10:13 am
Mine arrived yesterday. As others have said these look like OEM (no packaging) but come with the Eagle (x-synch 2) chainring. Not surprisingly they were a straight swap for my GX Eagle GXP cranks (5 minute job). I’m using a 24mm Hope BB with the Hope GXP adaptors. No need for any wavy washer.
Perhaps a bit more surprisingly the total weight saving over the aluminium GX Eagle cranks was 67g and that includes dropping from a 32 to a 30 tooth chainring. But they look nice and barely cost any more than the chainring, which is what I was after.
I tend to get a bit of heel rub on cranks, so it was nice to see that they come with a bit of tape in the relevant area already.
Oh and the X1 Eagle chain that Wiggle marked as 9-speed in the description is, of course, 12 speed really.
Posted : 07/04/2019 10:26 am
I’m glad quite a few of you found the PSA useful.
Posted : 07/04/2019 10:37 am
Roverpig, what did they weigh with the 30t chainring on?
Posted : 07/04/2019 1:04 pm
564g according to my kitchen scales. That’s as they came, minus the protective plastic cap over the splined end of the axles and the two pedal washers in a bag that were zip tied to the other crank.
GX Eagle cranks with 32T ring were 631g in the same state on the same scales.
Posted : 07/04/2019 1:10 pm
570g with 32t chainring
Posted : 07/04/2019 3:25 pm
The 2 washers obvs for the pedals,yeah?
Posted : 07/04/2019 4:54 pm
Yep
Posted : 07/04/2019 9:04 pm
Do these cranks have carbon arms? Some descriptions say they do but mine arrived today and are scratched on the nds arm and it’s silver underneath.
Posted : 08/04/2019 10:02 am
I currwntly run 10sp.
If i wanted a 10sp chainring, what do i buy? It has come with an x-sync 2 ring that i think is eagle 12sp.
Posted : 08/04/2019 11:17 am
By shear coincidence i'd seen those sort of figures just before the Wiggle deal happened - it made them annoyingly hard to convince myself to buy!
Posted : 08/04/2019 11:46 am
