Think you can even use cyclescheme too so it'd be 1800 ish?
https://www.evanscycles.com/brand/specialized/turbo-levo-29-2022-electric-mountain-bike-917898
Great price, even if you are going to chuck half of it away.
Smaller battery on that spec too. Nothing wrong with it, but 500 versus 725Wh would make quite a difference
Those bargain Lyrik forks would go nicely on the mint green spec......
Showing as 3849 for me
The next model up looks like a much better specced bike, thankfully they don't have a large 🙏
When the previous Levo was brand new I got the equivalent base model but had my LBS put a proper fork and brakes and a dropper on it.
Five years on I’m still riding it most days, and most of the other parts have changed but the frame, battery, cranks and saddle are still original (the upgraded fork, brakes and dropper are still there too - but the fork is on its second damper and the second CSU has had a new steerer glued in).
It's about £800 more as long as you don't buy the blue one. Seems like it would be worth it for upgraded shocks from basic Rockshox to Fox and the groupset from sx to gx.
It’s about £800 more as long as you don’t buy the blue one. Seems like it would be worth it for upgraded shocks from basic Rockshox to Fox and the groupset from sx to gx.
and a bigger 700Wh battery, that base one only come with the 500W, for just under £4K
The better one seems to be 1800 more to me as you can't use the voucher?
The better one seems to be 1800 more to me as you can’t use the voucher?
Seemingly no discount on the blue one & the red one wouldn't initially, but then I clicked on the black one and the discount applied (via browser), then messing around/checking I removed the black one added the red again and it seemingly applied the discount. Hmm can't get it to repeat now... but at one point I definitely had a Comp listed for £3919
