[url] http://www.lidl.co.uk/uk/home.nsf/pages/c.o.20090622.p.Road_Racing_Bike.ar1 ][/url]
Ultegra 'n all. No clues where the frame is sourced though.
Linky no worky...
Road Racing Bike
This top of the range racing bike is a must for any serious cyclist containing the very latest components from world renowned manufacturer SHIMANO, this is truly unbelievable value!
Top quality lightweight & sturdy Aluminium frame with aerodynamic design for minimised air drag
Weighs only 8.85Kg*
*53cm Frame, without pedals
Ultra lightweight & rigid carbon fork
3 different frame sizes available:
Rider height:
- up to 5ft 7" (up to 170cm), frame size (cm): 53
- 5ft 7" - 6ft 1" (170cm - 185cm), frame size (cm): 57
- 6ft 1" plus (185cm plus), frame size (cm): 60
ULTEGRA Shifters - STI Dual Control Left ST-6603, Right ST-6600
- Ergonomic design: Refined lever hood for improved ergonomics
- Robust internal mechanism
- Same lever response as Dura-Ace
ULTEGRA Dual-Pivot Brake Calipers BR-6600
- Compact & lightweight design
- Improved brake shoe durability
- Adjustable brake shoes for more or less modulation
ULTEGRA Hollowtech II Triple Front Crankset FC-6603
- Gearing: 52-39-30T
- Hollowtech II crank and bottom bracket combines hollow forging technology with integrated crankset & bottom bracket
- Hollow crank arms provide amazing strength and rigidity at a light weight
- Special tooth profiles, pick-up spikes and ramps make front derailleur shifts quiet, easy and trouble free for the rider
ULTEGRA 10-Speed Cassette Sprockets CS-6600
- 12-25 tooth combination
- Computer designed Hyperglide (HG) sprockets incorporate specifically positioned shift ramps and tooth profiles for improved chain control during shifting
- Fast and responsive indexed shifting
ULTEGRA Rear Derailleurs RD-6600 GS
- For use with triple gearing configurations - max front difference 22T
- 9 & 10-speed compatible
ULTEGRA Front Derailleurs FD-6603 ULTEGRA Super Narrow Chain for 10-Speed CN-6600
SHIMANO Wheel Set WH-RS10
- Front 16 spokes, rear 20 spokes
- Black anodized rim with Shimano logos
- Aluminium rear axle and freehub body
- New wider flange hub and offset rim for rigidity
- Ultralight 10-speed specific alloy freehub body
- Weight: 1,848 grams (pair)
Continental Grand Prix Tyres
SHIMANO PDR-540 Pedals
Shoe plates & tool kit included
Ultra lightweight (weighs only 196g) & stylish design with Manganese rail
3 year manufacturer's warranty
Price per item
749.00*
Only available while stocks last
Thanks mudshark... that's the one.
Maybe it is region specific?
Wow they designed them on a COMPUTER! They must be good then! 😛
Pretty good price for a bike with Ultegra though innit.
Must be region specific, not appearing on my lidl newsletter
You'd probably be a lot better off buying one of these:
http://www.boardmanbikes.com/road/road_comp.html
The URL in the first post has a "]" at the end which stops it working
Wasn't showing for me, but when I switched store location from GrimUpNorth to ThatLondon it's showing now, in the 22.06.2009 tab.
