Good price that, fits a 520 spot on as well as those listed on the site. I shall be collecting mine later.
Cheers! Under £5 with BC discount
Top spot! Bought two 🙂
Good find.
Great find, thanks!
I don't think this one will fit the 1000, but can someone confirm this?
Many thanks Andyeez! Just ordered 2.
Good spot! Bought 2 thanks
definitely worth ordering (at least) 2 - it's a great mount but (as I found out) annoyingly Garmin don't sell spares of the sacrificial part that the Edge clips into
Just wondering - can you fit it 'upside down' and re-fit the actual Garmin mounting piece on the other side, so the dog leg goes the other way?
I have my Garmin fitted to the left hand side of the bars, so would ideally like it kinked to the right, rather than the left.
I don't think you can Stumpy, the bottom of the mount is solid so I can't think how you'd flip it.
Thx bought one
lunge - MemberI don't think you can Stumpy, the bottom of the mount is solid so I can't think how you'd flip it.
Ta. I did wonder if that would be the case - but thought there might be a slim chance that the insert could be flipped.
Might get one anyway & see how it goes.
The clamp is probably about 4mm wide, so that’s all you’d have to free up to the right of the stem clamp
I picked up two yesterday.
The insert the Garmin clips into can be removed from the holder (two allen head bolts)
I wanted to try one flipped so rather than out front it sits alongside the stem.
Quick test fit and all seems good.
