PSA Cheap X-Fusion ...
[Closed] PSA Cheap X-Fusion Sweeps at Planet X
9 Users
Just noticed these in a Planet X newsletter.
Roughcut Sweeps, Black £349, White £299
Have been running a set for a year now - decent forks imo.
https://www.planetx.co.uk/c/q/components/forks-and-shocks/suspension-forks
They've got some cheapish Recons & Sektors too.
Posted : 06/11/2018 1:34 pm
Seen those sweeps and understand they could be internally adjusted down to 140mm travel which is what I’m after - but I want a black fork and on principle I won’t pay an extra £50 over the white one for the same fork! Hoping for some Black Friday deals.....
Posted : 06/11/2018 1:54 pm
aesthetics are expensive!
Their aero TT lid which the Mrs races in was amazing VFM at £50. If you can stomach a blue one then theyre trying to shift them fro £25! Nuts!
Posted : 06/11/2018 1:57 pm
They can, you'll need some tools such as a little pin spanner and some punches. Helpful to have a vice, too.
Posted : 06/11/2018 3:53 pm
And they're back, at £250.
In Black 🙂
Posted : 13/04/2019 6:44 pm
Finally. Been there since yesterday lunchtime. Wondered when someone would spot them.
Posted : 13/04/2019 9:45 pm
 StuF
Are they boost ones?
Posted : 13/04/2019 10:26 pm
Nope.
X-Fusion McQueens are the boost version.
Posted : 14/04/2019 5:01 pm
Just in case anyone's interested, now 250 quid for an X-Fusion Roughcut Sweep at Planet X.
Posted : 26/07/2019 9:55 am
https://www.planetx.co.uk/deals/q/deal-FOXFS27RC
Posted : 26/07/2019 10:23 am
Can the travel on these be changed to 130?
Posted : 26/07/2019 11:06 am
Yes. Some of them can be changed in 10mm increments, in the others you drop them to 140 and use a 10mm spacer as well. I think the Fox ones fit.
Posted : 26/07/2019 11:26 am
Thanks
Posted : 26/07/2019 11:27 am
Online docs seem to suggest it can be set at 120, 140 or 160
http://www.xfusionshox.com/service/fork-travel-adjust
Posted : 26/07/2019 11:28 am
You can set travel at 20mm increments by moving a pin and another 10mm with an additional spacer. Fiddly but mostly straightforward.
Posted : 26/07/2019 11:38 am
 StuF
It's a simple job to swap the travel, the only extra tool you need is the pin spanner. A small socket can be used knock the rebound shaft back into the fork and I used the wrong end of an old 5mm drill bit to knock out the travel adjust pin.
As BWD said, you'll need a 10mm spacer if you want to go to 130
There's a good video of how to do it on youtube.
Posted : 26/07/2019 12:01 pm
