Looks a bargain, had to talk myself out of it 'cos I have no use for it
https://www.chainreactioncycles.com/ie/en/race-face-ride-st-chainset/rp-prod208564
It's only cinch mount rings. Not cinch axle (30mm). Still good price.
Yeah, same as Aeffect, fits a standard shimano BB
That's worth it just for the ring, the cranks are basically free. Damn these PSA's, just bought 2 pairs of forks and some cranks last month...
Am I right in thinking that'll be a steel chainring? (which is good IMO)
It looks like it, yes.
Well now I have a spare set of cranks. To be fair, I have three bikes they'll fit with quite aged cranksets so I don't feel too bad. Probably cheaper than buying a new ring for one of the ones that's wearing.
51mm chainline, is that boost no boost or on the fence?
It's a 137mm spindle and there's also a 190 version listed on the Raceface website, so I'm guessing this one in non boost. Or maybe the 190 is for fat bikes? I dunno.
yeah, 190 is fatbike.
You can flip the rings on most cinch cranks so you've got a bit of control over chainline.
This is the sort of dangerous deal that makes you build a whole new bike isn't it? I have no use for these cranks at all buuuuut
That makes more sense. Quick Google suggests that it's ideal for Boost, but probs OK for non Boost:
This is the sort of dangerous deal that makes you build a whole new bike isn’t it? I have no use for these cranks at all buuuuut
Yep, these and a set of those 29 boost pikes thatw ere too cheap to ignore are on their way.
Now to buy a frame and wheels.....
Dammit, I've now made use of THREE PSAs in the past few weeks. First the 30% off Adidas TrailCross flats, then the PIkes last night, and now a chainset. Thanks but also YEAH, THANKS to the posters.
Damm ... usually ride 170mm cranks and looking for a replacement for my bikepacking bike , will 5mm make a huge difference ?
No probably not and even if it does they are cheap enough I don't think you'll loose anything.
For what it's worth the arms on my 170 and 175 Aeffect are both the same length, just the pedal holes are in different places..
if only they were 165 ...
