PSA cheap pike sele...
PSA cheap pike select plus at CRC
65 Users
https://www.chainreactioncycles.com/mobile/rockshox-pike-select-plus-boost-fork-2020/rp-prod208358
£380 in 29x130. Looks a bargain.
Posted : 01/09/2021 9:33 pm
Ouch was just about to say what a good fork. But I bought same from CRC a week ago and makes me weep how much more I paid. It started with a £5 and seemed a decent price during partmageddon. Oh well, some threads best not reading!
Posted : 01/09/2021 9:44 pm
Oooh - would that make a good replacement for the Gold 35 on my Scandal ?
** heads off to check resale value of Gold 35s….
Posted : 01/09/2021 9:55 pm
Oooh – would that make a good replacement for the Gold 35 on my Scandal ?
I think it might just edge it, yes. 🙂
Posted : 01/09/2021 9:57 pm
In all seriousness, I've ignored forks completely for ages to avoid spending $$$ as they are all so crazy expensive so I don't know if this is significantly better or a "bit" better.
Is this a significantly better fork than the Gold35?
Posted : 01/09/2021 10:07 pm
 a11y
@davros, cheers for that. I’ve had them in my basket on Wiggle for a week or so, where they’re still £555 or so. Awesome PSA.
I don’t even have the frame I’ll be putting these on yet, but I highly suspect I’ll need them due to short steerer on current fork.
Posted : 01/09/2021 10:12 pm
 a11y
Hell yes. The Charger 2.1 damper is superb.
Posted : 01/09/2021 10:13 pm
Several steps up from the 35 I’d suggest.
Posted : 01/09/2021 10:14 pm
Thanks everyone.
Does anyone want to buy a set of barely used Gold 35s ? 😉
Posted : 01/09/2021 10:15 pm
I sincerely hop there is a set left in the morning when I get paid, exactly what I've been after!
Cheers OP!
Posted : 01/09/2021 10:30 pm
The Pike has got a lighter chassis, better air spring, better damper and better seals. Should feel a good chunk bette mr than a 35 - for that price you should go for it!
@bri-72 order another, then return the second against the first order. Or contact them and see if they will match price to avoid a return.
Posted : 01/09/2021 10:53 pm
Is the a worthwhile upgrade from a Z2 for someone that is fit and forget and how easy / much is it to change travel
Posted : 02/09/2021 2:17 am
I'm not familiar with the z2 but I can say it's easy to change the air springs to adjust travel. New air springs around £30-40 and you'd need the right oil for the lowers. It's a simple job once you've done it a couple of times. No reason why it wouldn't be fit and forget. It doesn't have the low speed compression adjust so that's one less thing to think about.
Posted : 02/09/2021 8:25 am
A few years ago Rockshox forks seemed to come with inconsistent / low levels of oil so sorting this out prior to riding seemed to be a thing.
Is that still the case or have they fixed it now so it can be just fit and ride?
Posted : 02/09/2021 8:37 am
Personally I'd just ride it. Then if it felt like it wasn't working correctly I'd take the lowers off to see how much oil drips out and replace it. Only needs 10ml per side.
My last set of 2018 revs looked to have the correct amount in. Seems odd that they'd be assembled dry.
Posted : 02/09/2021 8:57 am
Can the travel be adjusted with a different air spring on these?
Posted : 02/09/2021 8:58 am
The Z2 is essentially a heavy Fox 34 Rhythm. So I think the Pike would be lighter, stiffer and has a better damper than the Grip 1 that’s in your fork. So yes a worthwhile upgrade imo.
Posted : 02/09/2021 9:11 am
Has anyone received a set of these and know the offset?
Thanks
Posted : 02/09/2021 9:18 am
That is a billy bargain. Unfortunately it's not a tangible enough upgrade over my mini-Pike (Revelation with a Charger RC damper) to justify dropping £380.
Travel wise, I beleive these can be altered from anything between 120 and 160mm of travel.
https://www.tftuned.com/2021-c1-debonair-air-spring-upgrade-kits-lyrikyari-pikerevelation-2018/p3851
Posted : 02/09/2021 9:56 am
 a11y
I was keen to know that too but went ahead and ordered regardless. TBH not sure if I'd prefer them to be 42mm or 51mm offset...
That's my understanding too: https://www.sram.com/en/rockshox/models/fs-pike-selp-b4
Posted : 02/09/2021 10:08 am
Yowzers, that's crazy.
Set ordered for my hardtail build. I had been dithering about a set of Zebs which I'd conceded where going to be massive overkill on a steel hardtail.
A Lyrik would have been nice but not 3 x the price and an unknown amount of months wait nice.
CRC's tech chap on live chat confirmed the travel on these can be increased with a replacement air piston so I've taken a punt that this is true.
Posted : 02/09/2021 10:47 am
I'm a bit out of date on the ever changing axle standards. I think I'm going to need a new hub as I only seem to have a non boost (15mmx100) or a 20mm Pro2 evo in my spares box. Are these anything weird or just a 'normal' boost?
Posted : 02/09/2021 11:42 am
100mm pro 2 will fit with hopes official boost kit.
Posted : 02/09/2021 12:01 pm
I think you can get adapters for Hope hubs. I believe these forks are 'normal' 15 x 110mm boost. They are also torque cap compatible.
Posted : 02/09/2021 12:03 pm
Regarding offset, my friend ordered some through Wiggle and they were 42mm, which were to short for his already short frame.
Posted : 02/09/2021 12:06 pm
Awesome. I bunged an order in last night without knowing that detail, reasoning I could always return them if they were wrong.
I was searching the internet a couple of week ago for these with no joy and delivery estimates for forks are approaching Christmas, so I wonder where they turned these up from?? Looks like Tredz are going to get the SID's that I pre-ordered pre-cancelled. 😊
Posted : 02/09/2021 12:15 pm
53 left in stock. I want one, but already have a Charger'd Rev on my bike!
Edit. Now 41!
Posted : 02/09/2021 12:23 pm
 a11y
The frame I'm setting these aside for quotes a 44mm offset fork, so I'll be chuffed if they turn out to be 42s.
Edit: same fork (I think?) is still £555.99 on Wiggle - usually they match the pricing across both their sites, but not this time: https://www.wiggle.co.uk/rockshox-pike-select-plus-boost-fork
Posted : 02/09/2021 12:31 pm
I was tempted, but also have a 2018 rev with a debonair spring and charger 2.1 damper which effectively makes it the same fork. So no point for me!
Posted : 02/09/2021 12:56 pm
Got a set for the hell of it. Hopefully be able to adjust to 120mm for plus bike. If not I doubt I'll loose much.
Posted : 02/09/2021 1:30 pm
I've got a little used 120mm debonair spring assembly if anyone wants to buy it? Send me a PM if interested.
Posted : 02/09/2021 1:42 pm
also have a 2018 Rev with debonair and Charger damper but really struggle to get it to feel great on my hardtail. Maybe just me and my tuning but tempted with a new shiny fork and sell em on
Posted : 02/09/2021 1:49 pm
Are these current model Pikes any worthwhile amount lighter than a Fox 36 (Perf Elite, so same weight as a factory) ?
Posted : 02/09/2021 2:45 pm
thanks for the PSA @davros.
Ordered one last night for my new Banshee build. It'll replace a Fox 34 - another PSA from a couple of years ago.
Posted : 02/09/2021 2:54 pm
Thanks for the heads up! Mate has just bought it for his new build!
Posted : 02/09/2021 3:10 pm
Screw it. Ordered. I currently have a Recon RL at 130mm on my hardtail, this will be a nice upgrade there.
Also more suitable than my current Fox 36 for potential 'one bike to rule them all' shorter travel FS that might be incoming at some point to replace my 2 current bikes.
I 'paid' £320 with a voucher I had knocking about too. Can't go wrong really.
Posted : 02/09/2021 3:18 pm
Yep 42mm offset and got set last week. Previously running a 51
And didn’t think I’d notice difference but actually can. Is a bit twitchier in turning at lower speed I think, certainly different. Sure will get used to.
Posted : 02/09/2021 4:25 pm
That’s good to hear as I’ll also be going from a 51 to 42 if this is what they are and was a little concerned about whether it’ll matter.
It’s on a Scandal 29er which does have a bit of a “front wheel way out ahead” feel to it, and also slow speed steering can be a bit ponderous so potentially this could be a change for the better. I just hope it doesn’t lose its high speed stability.
Fingers crossed it’s a minor effect and overall for the better.
Posted : 02/09/2021 6:09 pm
Just found a SRAM tech doc that says 3" b+ rubber fits. Perfect, should loose some weight over the manitous I currently have, gain some stiffness and be rid of the hexlock axle.
Posted : 02/09/2021 7:34 pm
Was looking to put some SID 35 at 120mm on my 100mm xc bike to down country it. Figured I can put a 120mm damper in these for the weight penalty.
Or build a single speed ht for the winter.
Just orderd anyway
FML 😂
Posted : 02/09/2021 7:51 pm
aaaand they've all gone
Posted : 02/09/2021 11:06 pm
Ordered one yesterday, so thanks for that OP.
Posted : 03/09/2021 9:09 am
Whilst staying in a hotel this week for work and in an insomnia fueled knee-jerk reflex purchase I bought a set.
No idea why.
I've got wheels, drivetrain and possibly brakes.
Any similarly amazing deals on a modern 29er suspension frame out there?
I'm perfectly happy/capable to change the air spring so something with circa 130mm/140mm rear travel would be preferable in case I kill my (amazing) Trek Rail.
Great PSW by the way!
Posted : 03/09/2021 9:33 am
I don't think you can @dai1983 - SID's are up to 120 and Pikes are from 130. It's probably a limitation of the leg length.
Posted : 03/09/2021 9:38 am
Pike/rev work with 120mm air spring. I have a debonair one to sell if anyone wants it for their new fork.
Posted : 03/09/2021 9:52 am
Yeah I had Pikes at 120mm for years.
Fortunately I need 130mm this time though.
Posted : 03/09/2021 9:54 am
Oh, fair play. Everyday's a school day!
Posted : 03/09/2021 9:56 am
What I'm pretty is the SRAM model page for this particular fork even says 120mm.
https://www.sram.com/en/rockshox/models/fs-pike-selp-b4The b3 version page says the same.
Posted : 03/09/2021 10:23 am
While the Pikes look to have sold out, they are doing boost 34s at £499.
https://www.chainreactioncycles.com/fox-suspension-34-float-performance-elite-boost-fork-2019/rp-prod208361
Posted : 03/09/2021 4:26 pm
Just bought some ...
Spontaneous like ...
I hope they are good!
Posted : 03/09/2021 7:45 pm
Lyriks for £399 for those after more travel - 160mm
Posted : 03/09/2021 9:42 pm
I forgot how slow CRC are at sending parts having not ordered from them for a few years.
Ordered on Wednesday evening, still showing as “processing” now.
I did select free shipping, but I’ve got so used to very quick delivery from almost every other online vendor it seems a bit odd. Is it deliberate to encourage you to choose one of the paid shipping options?
Posted : 04/09/2021 11:03 am
Next to the free shipping option it says 7 days. They do it on purpose to make you pay extra for quicker shipping
Posted : 04/09/2021 11:17 am
Yes, I saw that and optimistically thought that it’s actually be quicker. Forgot that they deliberately slow it down which was one of the reasons I stopped buying from them a few years back.
I get it for cheaper items, but for a £400 purchase it seems a bit petty.
Still, fantastic bargain forks !
Posted : 04/09/2021 12:27 pm
I highly doubt the ones working in the warehouse are sitting around doing nothing waiting until day 5 to pick your order.
Not in a rush, pick free shipping and wait. In a rush / impatient pay for shipping.
Posted : 04/09/2021 3:31 pm
I normally find their free shipping is pretty quick for me, often next day or two day.
I am happy either way unless I paid for next day.
Good price on those and the Fox 34
Posted : 04/09/2021 3:47 pm
https://www.chainreactioncycles.com/fox-suspension-34-float-performance-elite-boost-fork-2019/rp-prod208361/blockquote >
extra tenner off with CLEAR2021
ELH 😉
Posted : 04/09/2021 5:41 pm
Cheers for the PSA, I purchased the Pikes, to replace some Gold 35s, but would rather have gone for the Lyriks. Now the Lyriks are available for £390 I've ordered them as well, so will probably return the Pikes or pass them on to someone else. Cheaper too as it means I don't need to order a longer air shaft 🙂
Posted : 04/09/2021 8:13 pm
What’s the damper and air shaft in the Lyriks? Are they the Debonair spring? And is it Charger 2.1 or the earlier one? Can’t work out what year they are.
Dilemma is to get these to replace a set of old Pikes on my RocketMAX or get a Charger upgrade for them. New Lyrik would also mean new front wheel as Pike is non-boost.
Posted : 04/09/2021 8:20 pm
if it helps they appear to have had a dump off ex Santa Cruz stuff, wiggle has a lot of SC length shocks, the fox up there are from a SC Tallboy in the 2018 Gloss Black/Rust colour
https://www.vitalmtb.com/product/guide/Bikes,3/Santa-Cruz/Tallboy-Carbon-C-S,19662
Posted : 04/09/2021 9:00 pm
Does that explain the brown logos on the pikes as well.
Posted : 04/09/2021 9:17 pm
@GeForceJunky im after a set of the oikes- have sent you a PM
Posted : 04/09/2021 10:27 pm
The Lyrik is listed as Charger RC so I guess 'Select' level whereas the Pikes are Charger 2.1. I was under the impression they are very similar in practice.
Posted : 04/09/2021 10:32 pm
Pikes sound like they are off a 2020 tallboy
Posted : 04/09/2021 11:56 pm
Ordered pikes but unsure to stick with them or go for lyriks
Does anyone know which is better? I believe the pike is the mid level pike and the lyrik is the bottom of the range with lower spec damper but is more burly? Can someone correct me if I am wrong?
Posted : 06/09/2021 7:48 am
 a11y
If it makes a difference to you, the Pikes are 42mm offset and the Lyriks are listed as 51mm offset. Generally Pike is lighter/less burly than the Pike. And I admit I'm a bit lost as to what adjustments the different charger dampers have.
Posted : 06/09/2021 8:46 am
I’d say the pike will be lighter/plusher looking at the spec. If your a big/hard rider that likes to send it get the lyrik.
The lyrik is 160mm and pike 130mm ? Are you planning on increasing travel on pike ?
Posted : 06/09/2021 8:47 am
Lyrik RC will probably be an older fork, potentially with the HSC set firmer.
Still a very good buy at that price, especially if you are a heavier rider. And better on a RocketMAX than a Pike (more sturdy).
My Pike arrived yesterday.
As the stickers are separate, I may buy some to match my blue frame stickers.
Who's good for custom stickers?
Posted : 06/09/2021 9:23 am
Was planning on running them at 140mm or 150mm which is making the decision harder
Posted : 06/09/2021 9:29 am
Considering the Lyriks. Worth it over a PIKE RCT3 debonair?
Posted : 06/09/2021 9:35 am
What do you weigh? Do you ride fast?
Posted : 06/09/2021 9:41 am
Who’s good for custom stickers?
Also interested in this. Could do with some burnt orange ones for my Whyte 629.
Posted : 06/09/2021 10:52 am
 a11y
Slik: https://www.slikgraphics.com/shop/forks/rockshox-pike-select-decal-kit-black-forks/. I'm vain enough that I'll be getting decals made that are a better match for my frame than the brown.
For me that's the cross over point: I've happy used Pikes from 120-140, but for 150-160 I've used Lyrik or a Chargered Yari. Sorry, doesn't help as I'd say Pike for 140 but Lyrik for 150.
Posted : 06/09/2021 10:53 am
From memory 29er pikes weigh 1875g and 29er lyriks weigh 2030g (ish)
Edit, crc states 1830g!
My friend swears by lyriks at 150 or 160 travel and he's about 5 foot 9 and slim. He's an aggressive rider and just prefers how they feel and ride over pikes. He's not bothered about the extra 150g.
But personally, I think anything 140 or lower, pikes are more than enough for most riders unless your a big rider.
Posted : 06/09/2021 11:01 am
I might take a punt on Invisiframe's blue stickers. One of the best little MTB companies IMO.
Slik graphics are awful to deal with !!
Posted : 06/09/2021 12:30 pm
I didn't think I was terribly suggestible. But...
Stage 1 - Thought that the decal colour REALLY doesn't matter - brown would be fine, or just leave them off. People getting decals to match their bike must be very vain.
Stage 2 - Thought I'd take a quick look just to see. Oh look, you can get orange, my bike is orange
Stage 3 - Now fretting about getting just the "right" colour orange as the bike is a kind of slightly muted "burned orange".
Thanks all !
Posted : 06/09/2021 2:08 pm
 a11y
That's never been my experience (multiple orders due to extreme personal vanity issues)
@markwsf - you DO realise you can then also get matching decals for your rims and rear shock? (if applicable) . Matching collar and cuffs etc.
Posted : 06/09/2021 2:13 pm
Just because you CAN, doesn't mean you SHOULD.
Posted : 06/09/2021 2:20 pm
Page 1 / 3
