PSA - Brand X dropp...
[Closed] PSA - Brand X dropper XL (150mm drop) £99.99 at CRC
15 Users
 nre
I'm pretty sure this was still around £125 a few days ago (I checked after the recent PSA for the 120mm drop version at £79.99).
The question is, do I return my recent (unused) purchase of the 120mm and swap to the 150mm...? Hmmm....
Posted : 23/02/2018 8:03 am
Yes, if it fits then definitely!
There's no way of saying this without sounding very Kenneth Williams, but that extra inch makes a big difference IMHO.
Posted : 23/02/2018 8:11 am
Good PSA, I persuaded a friend to buy the 120mm last week, let’s hope he hasn’t fitted it!
Posted : 23/02/2018 8:17 am
thats 8 quid saving over my psa a month or so ago! get one! bargain!
Posted : 23/02/2018 9:01 am
 JAG
Only available in Stealth routing version - Phew!
I just ordered the Brand-X Ascend II 125mm drop for £124.99
I thought for a moment it may be gong back before it arrives - if you know what I mean 😀
Posted : 23/02/2018 10:30 am
F***!
Ordered last night at normal price! 😡
Posted : 23/02/2018 11:14 am
Actually,no, on the invoice it shows as £99.... And I used a BC code too. Bargain!
BX droppers are great!
You can keep your Reverb tat. 😀
Posted : 23/02/2018 11:18 am
Great price. I got mine last year at the £150odd price and even then thought it was a good buy.
The remote isn't the best but the action is smooth and it's not sagging yet!
Posted : 23/02/2018 12:52 pm
Epic PSA.  Been holding out for one of these to drop in price again.  £92 inc delivery with BC discount.  Happy days.  Nice one OP.
Posted : 23/02/2018 1:03 pm
The remote isn’t the best but the action is smooth and it’s not sagging yet!
There is solution to that....
[url= https://farm5.staticflickr.com/4655/40394218112_f614373bc5_b.jp g" target="_blank">https://farm5.staticflickr.com/4655/40394218112_f614373bc5_b.jp g"/> [/img][/url][url= https://flic.kr/p/24xuVJq ]Dropper Post Heath Robinson[/url] by [url= https://www.flickr.com/photos/matt_outandabout/ ]Matt Robinson[/url], on Flickr
[url= https://farm5.staticflickr.com/4694/40394218242_0263e7ac93_b.jp g" target="_blank">https://farm5.staticflickr.com/4694/40394218242_0263e7ac93_b.jp g"/> [/img][/url][url= https://flic.kr/p/24xuVLE ]Dropper Post Heath Robinson[/url] by [url= https://www.flickr.com/photos/matt_outandabout/ ]Matt Robinson[/url], on Flickr
https://www.vitalmtb.com/features/How-To-Connect-Your-Dropper-Post-to-Shimano-or-SRAM-Front-Shifter,839
Posted : 23/02/2018 1:11 pm
I think the standard paddle trigger isn't too bad at all.
That said I've bought the Bontrager trigger for £17.50 and it is better built for sure.
Posted : 23/02/2018 2:22 pm
I thought standard was 'ok but wobbly' as STW did.
6 months in, due to being so small, the clamp was done up tight to stop it rotating and I rounded the bolt. It was also by now wobbling as much up and down as forward and back...
I just decided that rather investing in 'iffy' lever, I could invest faff time in lush 9sp XT lever. It took about 10 mins to bodge that up, and sooooo much more solid.
Posted : 23/02/2018 2:43 pm
Re: The lever I've used a Bontrager Drop Line remote from Triton, you'll need to open up the BX cable grub screw with a 4.5mm drill bit and drill half way through to accept the gear inner nipple, might also need to smooth off the nipple head with a file too. The bonus of this is a better lever and the cable is then fixed at the remote end which is easier to install. I also added a bit of grip tape to the remote lever for added, err... grip.
Posted : 23/02/2018 3:19 pm
Cheers Nre. Ordered to replace my Giant dropper which will be going on the classifieds once the BX dropper arrives....
Posted : 23/02/2018 7:50 pm
<div class="bbp-reply-author">
qwerty
<div class="bbp-author-role">
<div class="">Member</div>
</div>
</div>
<div class="bbp-reply-content">
Re: The lever I’ve used a Bontrager Drop Line remote from Triton, you’ll need to open up the BX cable grub screw with a 4.5mm drill bit and drill half way through to accept the gear inner nipple, might also need to smooth off the nipple head with a file too. The bonus of this is a better lever and the cable is then fixed at the remote end which is easier to install. I also added a bit of grip tape to the remote lever for added, err… grip.
Good point!
I hope BX/ CRC don't consider that a warranty killer? I'm guessing I could just send it back without the little grub screw part anyway. As that is all you are modifying of if I understand correctly?
</div>
EDIT: Actually I think I will just use the grub screw/barrel as is. So effectively I just use a gear cable cwith both ends cut off. That'll work fine too. 😊
Posted : 23/02/2018 9:20 pm
 Neb
I've just bought one as well, is the included remote really that bad? Is the bontrager dropline remote a better solution than buying a modified shifter?
Wondering whether to just buy/install it all at the same time or not..
Posted : 24/02/2018 10:15 am
I got the 120mm normal version....haven't opened the box yet, but I understand it comes with a lever much like a left hand gear shifter as standard?  Which would clash with a left hand front shifter?
So you either buy the after market paddle shifter, or go 1x10?  (I'm on 2x10)
Or are there any other cheaper/better solutions?
Posted : 24/02/2018 10:18 am
 Neb
I installed it tonight and I'm initially impressed. The remote isn't great, but it'll do for the moment. Nice on OP, good PSA!
Posted : 27/02/2018 7:55 pm
Just an FYI....
Bought and fitted the Bontrager shifter.
It works ok but really could have done with a return spring in the lever as the spring tension from the dropper is just about enough to return the lever to it's place. Not helped by a sharp bend in the cable on my frame...
So yes, it does work but with a slight niggle in my case. Nice quality shifter though!👍
Posted : 27/02/2018 8:12 pm
Can someone measure the minimum saddle height possible, think I'm too much of a shortage shortarse for this post.
Posted : 27/02/2018 8:39 pm
From bottom of collar to middle of saddle tail?
Posted : 27/02/2018 8:59 pm
Said measurement is 20.8cm.
Posted : 27/02/2018 9:40 pm
Ooh, with the bonty remote, it's return action is much improved with a bit of oil on the bushing so it's all good. :D👌
Posted : 28/02/2018 2:18 am
Can someone measure the minimum saddle height possible, think I’m too much of a shortage shortarse for this post.
Akira, my last measurement was max saddle height.lol
Minimum, from bottom of collar to middle of saddle rail is approx 62mm. Hope that helps.
Posted : 28/02/2018 2:24 am
Wolftooth Remote for mine.
Posted : 28/02/2018 5:32 am
Cheers poopscoop, as I though I'm a bit too short for this, might have to get the 125mm one instead.
Posted : 28/02/2018 8:14 am
