Lovely Thank you !
Just a heads up, I believe these only fit the older E8000 motor and not EP8
E61**, E7000 & E8000
Good shout there isn't a lot of detail to go on and that would help explain the level of discount. Were they labeled XT when the E800 was current?
I'm trying to think what I put on my Rise with an EP8 , they might have been E900's
Ooops - thank you off to cancel - were to go on a rise with an ep8
Brilliant , just what i need, except i
ll have to get an ebike to go with them.
So I got the 10speed 11-46 cassette i wanted anyway, back down to 24.99
I looked for exactly the same reason.
Are they the same as these? Shimano list them as EP8/ E800 Series if that is confirming compatibility.
https://bike.shimano.com/en-EU/product/component/ep8-ep800/FC-M8150.html
In the Q&A on the Chain Reaction page someone has said they fitted them to an EP8 equipped Marin.
Edit: I can see now the XT Logo isn't in the same place as those on Shimano's web page
this is correct. I purchased and returned them - they do not fit the ep8 as they don’t fully seat/extend past end of splines on the axle (I tried them and compared fit to the 8150 cranks.
How have they made buying crank arms so bloody complicated?
jp that's standards for you 🙄
You need either FC-EM600, FC-M8150 or FC-EM900 for EP8 motors.
You'll need M8150 for a Rise (or other ep8)
I made that mistake buying some cheap 8050 cranks (not £17.99 cheap!) which I had to return and buy some not so cheap 8150s.
But still, £18 is stupid cheap
