Properly lubricated...
[Closed] Properly lubricated fork seals
11 Users
Hi,
My first post so sorry if everyone is already aware of this.
My bike hangs upside down between rides, which allows the oil in the fork to keep the foam rings and the seals permanently lubricated. It is not my idea - I read it somewhere and cannot remember where however, it is a brilliant idea! My fork feels really smooth right from the start of each ride, as if it had factory fresh seals. Try it!
Lewis
Posted : 06/04/2015 9:01 pm
weird first post
but with my pikes, they feel nicer after i do the zip tie in the seals drip in some lube trick every so often
Posted : 06/04/2015 9:03 pm
I read somewhere that storing upside down can introduce air into brakes ......
Kimbers...... What is this trick ?? ...... Push a cable tie in and then oil? Doesn't that damage seals ??
Posted : 06/04/2015 9:06 pm
http://www.vitalmtb.com/videos/features/How-To-Bike-Lubes,27659/Arts-Cyclery,27344
3mins in, tho i pop the little spring off from round the seal 1st
Posted : 06/04/2015 9:10 pm
.....or buy some Fork Juice !
Posted : 06/04/2015 9:36 pm
Posted : 06/04/2015 9:40 pm
 nuke
Big fan of fork juice but its still just external lubrication unlike that ziptie/fork seal tip...crackin suggestion and am going to give thst a try
Posted : 06/04/2015 9:42 pm
Still using Brunox stuff after 3 or so years. Run down the leg, pull the seal back with my finger nail to let it run in, jobs a good 'un.
Posted : 06/04/2015 9:58 pm
/\ That looks like a wicked idea, silicon overspray all over your disc
Posted : 06/04/2015 10:18 pm
@ wysiwyg - I wrap the disc rotor and brake caliper up with a plastic bag before I spray the stanchions. Never had a problem this way and it saved removing the front wheel.
Posted : 07/04/2015 7:20 am
yeah defo cover your discs!
Posted : 07/04/2015 8:00 am
I just lay bike over at about 60 degrees and spray,then upright and pump the fork up and down.... Sorted 🙂
Posted : 07/04/2015 8:11 am
Something buggerup my foam rings.
I'm thinking it might have been shoving the ziptie in too far.....
Be careful out there 😀
Posted : 07/04/2015 8:24 am
You did take the cable tie back out?
Brunox Deo is good too, wee bit thicker than fork juice and also sounds like an 80s men's hairspray.
Posted : 07/04/2015 8:35 am
Of course I did! 🙂
I think it just snagged it and caused it to get sucked down into the lower.
There was loads of stiction and when I dropped the lower off it was like a sponge you leave under a plate overnight when soaking the dishes 😉
Posted : 07/04/2015 9:11 am
