Problem with 2 x 9 ...
[Closed] Problem with 2 x 9 set up on Cube Reaction
1 Users
 Moda
Tried to run a 2 x 9 setup on a Cube Reaction with an XTR M970 crankset. Used Ta 38 middle and 26 inner rings but when you use a spacer the inner ring it is to close to the frame. Its a BB30 pressfit so apparently you cant use spaces to adjust it. Anyone else over come similar issue ?
Could i run an XT 36 middle and 24 inner on this chainset?
Any input much appreciated.
Posted : 30/01/2011 12:10 pm
