Pro4 rear hub to bo...
[Closed] Pro4 rear hub to boost conversion?
6 Users
Due to a warranty frame replacement I need to go boost at the back. Currently running a 142 Pro4.
Can it be converted or do I need new hub and rebuild?
If it can be converted am I ok with my "normal" chainset and just space as needed to get the chainline?
Posted : 15/09/2016 7:52 pm
Your rotor won't be in the right place for caliper. So new hub required afaik
Posted : 15/09/2016 7:58 pm
Lindarets boostinator.
http://www.lindarets.com/boostinator/
If you can get one!
Posted : 15/09/2016 8:09 pm
Was it bought as a frame only or bike?
Posted : 15/09/2016 8:14 pm
Frame only. Think I'll just upgrade up and sell on the old one
Posted : 15/09/2016 8:36 pm
Sometimes the crankset will foul the chainstays too buddy...If you're lucky enough not to have that issue, you'll have heel rub for damn sure 🙂
Boost specific cranks mucker...Sorry to be the bearer of possible bad news mate.
Posted : 16/09/2016 5:21 pm
Fingers crossed I can space it. Already need a new seat post too. Why cant they leave shit alone!!
Posted : 16/09/2016 8:03 pm
Really.
What about cranks that can be run as boost or none boost with just a change of chainring?
I'm sure that the Q factor on XT cranks is the same for boost and none boost too. The only difference is 3mm in chainline.
Posted : 16/09/2016 8:15 pm
The ones I've had have all needed the specific cranks, but I'm sure this may only be like I say, in 'some' cases...I've just had crap luck it appears. I know XT make a Boost specific crank if that helps.
I built up a Trek with XTR that definitely needed specific cranks - Just info that worth looking into should you have issues 🙂
Posted : 17/09/2016 10:57 am
