Price of 11-speed c...
[Closed] Price of 11-speed chains!!
10 Users
Just bought a nearly new chainset off eBay and now looking to buy a new chain, but the price for KMC X11L at £28 is approaching what I paid for the chainset! Why are they so expensive and anyone know the cheapest place to buy?
Posted : 22/02/2016 10:59 pm
Shimano 105 chains are usually about a tenner from Wiggle et al.
Posted : 22/02/2016 11:01 pm
and the friggin split link is not reusable!
Posted : 22/02/2016 11:02 pm
I've bought KMC and SRAM both from CRC for about £16 each. They'll be lower end than a £28 chain of course.
Probably this one:
[url= http://www.chainreactioncycles.com/sram-pc1130-11-speed-chain/rp-prod123726 ]http://www.chainreactioncycles.com/sram-pc1130-11-speed-chain/rp-prod123726[/url]
Posted : 22/02/2016 11:13 pm
The existing chain (very low milage) is a KMC X11L and as I need extra links, I was hoping to get an identical new chain and transfer remaining links to the old chain giving me a second chain; is this doable?
Posted : 22/02/2016 11:14 pm
Sram PC 1130 = £15.99 @ CRC
Posted : 23/02/2016 7:42 am
What's the point, they're a throw away item anyway.
Posted : 23/02/2016 8:23 am
[quote="badgerbater"]is this doable?Yes.
I have no idea why you'd want to though.
You'll just end up with another chain thats too short. And once your first chain is high mileage, and due for replacement, it's not like you'll be able to reuse the links.
Posted : 23/02/2016 10:07 am
[quote=ghostlymachine ]You'll just end up with another chain thats too short.
Only if he needs the full length of the new chain, which is unlikely.
Posted : 23/02/2016 10:23 am
But quite possibly going to need enough of it to make it too short to use........
Posted : 23/02/2016 11:01 am
 qtip
Either way, he needs a new chain. It wouldn't be that surprising if the number of links removed to fit the new chain would make the old chain long enough. Makes sense to me.
I also wouldn't be too surprised if you could join together 2 completely different 11-speed chains with a split link and not notice any difference in functionality.
Posted : 23/02/2016 12:40 pm
Thanks for the replies. Reason is, I'm replacing a 46T chainring with a 50T and hoping (haven't yet counted the existing links) that I'll have an extra 4ish links to play with!
Posted : 23/02/2016 8:29 pm
or butcher a 10sp for some inner links and use 11sp split links to make it a little bit longer, it'll be fine
10sp is 5.88mm width, 11sp is 5.62mm - pitch is the same for both
Posted : 23/02/2016 10:34 pm
