Pressfit Bottom Bra...
Pressfit Bottom Bracket removal tool - cheapo ones any good?
16 Users
24 Reactions
Well, I've got far in life without having to ever do this and only got the one bike with a pressfit bb so don't expect to be doing it too often. But the graunch of doom means it's time for the bearing grim reaper to take its next victim.
As ever the default tool is Park and as ever the price for the real thing is juicy at £40+ . https://www.parktool.com/en-int/product/press-fit-bottom-bracket-bearing-tool-set-bbt-90-3
Plenty of much cheaper alternatives from ebay/amazon etc like this - https://www.amazon.co.uk/Bearing-Removal-Cycling-Bracket-Stainless/dp/B0D4V2QJ93?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A2QNPJ4RQMWGL
Anyone used the cheap and cheerful version? Made of cheese or up to the job?
Ta
Posted : 21/07/2024 7:48 pm
 cp
Yeah I use one. The fingers needed spreading more before use but it worked perfectly fine.
Posted : 21/07/2024 7:59 pm
convert and convert reacted
Not really any cheaper but the prospect of using variations on the park tool and whacking away at a carbon frame with a mallet gave me the willies so a bit of googling revealed there is another way..
https://www.merlincycles.com/unior-1625-bottom-bracket-removing-tool-113862.html
Set the tool and wind the nut to gently(?) pull the cups/bearings out.. kinda how a bearing press works but in reverse.
Posted : 21/07/2024 8:17 pm
ocrider, convert, ocrider and 1 people reacted
Bsc tools every time
Posted : 21/07/2024 8:28 pm
The thing that worries me with that puller is that you have to push against the frame.
Posted : 21/07/2024 8:46 pm
I use an Icetoolz "rocket" tool, same as the Amazon one in the first post (though it was £17). Folk have been using the same technique for headsets for as  long as I've been mechanicing and it works just fine.
Do you have a bearing press for fitting the new BB?
I have both if you want to borrow them.
Posted : 21/07/2024 8:47 pm
leffeboy, convert, leffeboy and 1 people reacted
Thanks for that. My headset press should work I think - I'll need to go measure.
Posted : 21/07/2024 8:56 pm
ceept and ceept reacted
Having used that Unior BB puller, can I just say that it's a cathartic experience worth every penny.
Posted : 21/07/2024 8:58 pm
https://www.bearingprotools.com/collections/bearing-presses-for-bottom-brackets/products/bottom-bracket-bearing-puller-expanding-type
I've got some of their hub bearing presses so just ordered a bottom bracket extractor from the above. Not much more than the cheap type you're looking at.
Posted : 21/07/2024 9:00 pm
I have a BBB Bracket kit https://bbbcycling.com/uk_en/btl-95-bracketkit which has a removal tool and press tools. It's worked fine on several different bikes.
Posted : 21/07/2024 9:03 pm
These do the job nicely
https://wheelsmfg.com/presses-tools/bottom-bracket-tools/6806-30mm-sealed-bearing-extractor.html
Other sizes available.
Probably only worth getting this style over a cheaper rocket type one if you want to keep the cups and replace the bearings only. But I found the cups would normally come out with the bearings.
Posted : 21/07/2024 9:24 pm
Not all pressfits are the same, but, I always just whacked mine out with a drift and whacked them in with a rubber mallet. That was whatever bullshit Trek were using in 2014 or thereabouts, I forget the name.
Posted : 21/07/2024 9:55 pm
> https://www.merlincycles.com/unior-1625-bottom-bracket-removing-tool-113862.html < Set the tool and wind the nut to gently(?) pull the cups/bearings out.. kinda how a bearing press works but in reverse.
Guess what I made today?
It does, indeed work a treat. No violence required.
@convert - if you are in/passing N Wales coast, you are welcome to borrow.
Posted : 21/07/2024 9:57 pm
ocrider, convert, petefromearth and 3 people reacted
Tap it out with a mallet and flat head screwdriver, go slow and work around the  internal and they should slowly pop out.
Posted : 21/07/2024 10:29 pm
Is how I've removed every external headset in the last 30 years. But I think I'm going to tool up for this job.
Thanks everyone.
Posted : 22/07/2024 8:08 am
As part of an ongoing garage clear out I've a Park Tool BB removal tool lurking somewhere that will be going up in the classifieds soon. Can't remember the part number at the moment, but it may be of interest to you.
Posted : 22/07/2024 7:20 pm
Ice tools do one
https://www.tweekscycles.com/icetoolz-press-fit-bearing-removal-tool-wine293/
Their other stuff has been good when I've used it. These tools are fairly basic. I have the Park one but didn't pay anywhere near £40 for it. It replaced piece of copper pipe with a some cuts in the end.
Posted : 22/07/2024 8:07 pm
