Hi Guys
Can anyone point in the directions of some online instructions for this? I know TF used to have them but I can't locate them anymore.
Thanks
Take the Talas gubbins out and replace with float top cap?
Or is there more to it than that?
Off the top of my head...Deflate, remove lowers, remove air side top cap, unscrew talas cartridge. Using the supplied circlip, fit the alloy cup that holds air shaft/negative spring in place, fit air shaft/negative spring assembly, pour 5ml of fox fluid on top of seal head, replace top cap, inflate and then reassemble lowers with correct amount of oil.
It's pretty straightforward.
