Praxis BB30 bear re...
[Closed] Praxis BB30 bear replacement ?
5 Users
Whats best to do ? pop old out and replace bearings or replace the lot.
Only been in 6 months !!!
Posted : 06/01/2019 8:28 pm
I'd avoid the cheap pooh or you'll get all grisly.
Posted : 06/01/2019 8:30 pm
Just replace the bearings with angular contact ones in case your set up is putting excess side load on them.
Posted : 06/01/2019 8:31 pm
if you replace the bearings then you lose the warranty but then on the other hand, with knackered bearings (which aren't a warrantiable item) the BB is useless anyway.
They can easily be pushed out with a socket drift, new ones of whatever quality pushed in, and the system is excellent so well worth the effort overall. I've done that twice with a BB that is now about 5 years old (original and then 2 sets of aftermarket)
Posted : 06/01/2019 8:38 pm
gah, 40mpg urswine! 🤬
Cheers guys , will pop some new ones in. Will try those angular contact ones .
Posted : 06/01/2019 9:32 pm
