Should come with free stick on rubber bumpers.
Just put the stem on the right way up and it will be fine 😉
the Flatforce is intended for riders having a hard time finding a good position on longer-travel 650b and 29in bikes
A bit of blue-sky out-of-the-box throw-it-at-the-wall-and-see-what-sticks thinking here, but what if instead you made the wheels smaller, say 26"? Oh, wait...
But then the 'decals'* would be upside down! 😉
*Stickers, obviously.
There are pages other than the forum? Wow, learn something new every day
The bars/levers of all my bikes hit the top tube if the bars spin around in a crash, even with positive rise stems.
I may get that and stick it the proper way up. Ideal for my dodgy back, can get rid of all the spacers then too
Prezactly. I've tweaked my levers up a smidge so they don't on one of mine, but the bars'll hit first every time in that stem.
Looks like that stem has had one too many Stellas
That'd go nicely with my 50mm risers.
Want that 44mm one, frankenbike currently has a flipped 45mm on anyway, working on some bump stops for top tube 😉
A bit of old inner tube and some duct tape works. It looks gash, but it works 🙂
😀 True, but can't be see with that on the 'nice' bike 😉
[i]working on some bump stops for top tube[/i]
Maverick used to do some nice ones.
Just put some BikeShield on the TT
So does the stem!
Will match the rest of the bike 😉 and rider
Why not mount a normal stem between fork crown and lower headset bearing and be done with it?
It's a matter of leverage though.
For the same force at the bar end, there will be more pressure on the frame the closer the contact point is to the stem. That's why Lefties use a bump stop.
It looks like a solution to a problem that doesn't exist to me, but if it did exist, designing some sort of upside down riser bar would be a better solution.
[i]upside down riser bar[/i]
a Lower?
Sort of.
If you just turn a riser bar upside down,the grip parts will be angled downwards, a bit like sports motorbike bars.
I was thinking of something that drops from the middle,then rises up again slightly at the ends.
Brewer's Droop for your bars 🙂
What we actually need it he bars to be directly mounted onto the crown of the forks. This way we can use much larger wheels and look even dafter.
Theres a photo of a russian made track bike with bull horns protruding from the fork crown. Looks a bit odd as obviously it stil needs a conventional top tube and headset!
All solved by getting a bike that fits. Short people on big wheels look as ridiculous as I do on 26"
rOcKeTdOg - Member
All solved by getting a bike that fits. Short people on big wheels look as ridiculous as I do with this beard"POSTED 6 MINUTES AGO # REPORT-POST
And bizarrely I saw a one of those Lotus bikes on a bike rack in Annecy this summer. Or a very good copy.
Is it wrong that I thought this thread was going to be about the Diana film?
PS - could easily solve the problem by putting some spacers underneath 😀
Sounds like one of brant's godawful designs... 😉
[i]The bars/levers of all my bikes hit the top tube if the bars spin around in a crash, even with positive rise stems.[/i]
leverage doesn't come into it. The grips/levers will hit the cross bar before the stem, and they'll hit half way down. Lefties have a bump stop because a riser stem or bars set-up could well have the levers/grips clearing the top tube, allowing the fork to hit the frame.
Houns - Member
rOcKeTdOg - Member
its gone James, keep up at the back!
