Powerspline bottom ...
Powerspline bottom bracket question
4 Users
 SSS
So my goto bike is a Specialized Rockhopper, for evening and weekend runs/training.
It has a powerspline 68E/73 x 118 fitted. However ive found that they are made of cheese and need replacing often.
The BB is 73mm width on the bike.
the 68E/73x118 is like hens teeth just now.
The 68 x 113 is common as muck. Merlin in fact are selling them for £10 each. Rumour could be that its being phased out.
Question. I know the spindle length will be 5mm shorter (2.5mm) each end. Assume you could use a washer or spacer inside the crank arm hole to 'pad it out' to get back near 118mm. Ive measured and there is about 5-6mm between crank and chainstay at the moment. But what about using a 68mm instead of the 68e/73? Will it work? Can it be made to work?
Posted : 05/09/2024 12:22 pm
Sorry I can't answer your specific question, but my own personal answer when I had a bike with powerspline cranks and BB, was to replace it with a Shimano crank set. My logic being that I'd save money in the long run due to not needing to replace the BB every 6 months.
Posted : 05/09/2024 3:15 pm
Another who has replaced two powersplines with Shimano offerings. Much better and more reliable, and not much more to change.
Merlin often do Deore cranks for dafty cheap - like £35
Posted : 05/09/2024 3:35 pm
 SSS
Yeah, im looking at that just now.
Merlin have the NX DUB 12 speed on offer just now, so would need to change BB to DUB too.
Posted : 05/09/2024 3:49 pm
Again, DUB far less longevity than Shimano… go with the Japanese big S and be done.
Posted : 05/09/2024 3:51 pm
