Truvativ Hussefelt. Seems to be some conflicting anecdotal advice on the www
Allegedly after removing the crank bolts the crank arms just slide off or they need a square-taper crank puller 😕
Just wondered if anyone actually knows
Ta folks
Posted : 17/02/2015 10:29 am
If they are powerspline, not ISIS (not come across a powerspline Hussefelt myself), then technically you'll need a square taper puller, but in reality they often fall off under their own weight (even had brand new, and unridden ones do it).Powersline BB's also have the lifespan of a mayfly too.
Posted : 17/02/2015 6:52 pm
