I'm considering getting my Soul frame powdercoated a unique colour. Thinking a metallic purple or dark purple with 'sparkley flecks' in?
Browsing local powder coaters here in Stoke and after emailing a couple it seems I might have some trouble and will have to go for a standard ral colour.
Ideally I'd like to handle a few samples as I'm not sure of the exact effect/colour I want.
Do ral colours come up metallic after being treated somehow? I am a complete novice in this area so feel free to educate me.
Can I get a sparkley effect/colour?
Any recommendations for powder coaters in the west mids/nw are where I can handle samples to see the results?
thanks all.
Unless you go to a specialist you may struggle. I deal with a few powdercoaters and they mainly use specific ral colours. They can get most colours but won't unless the quantities justify it. Another consideration is that some won't do certain finishes and colours as they might not have the equipment. I wanted something sprayed fluorescent and no one would do it because of the mess it made of the gun. The companies I have had bike frames done at ideally like you to pick a stock colour and will do it as a foreigner with the next batch of that colour.
An option may be to get it powdercoated as a base colour then get a finish sprayed on top.
Yes you can get them done, LSN Coatings did some for our girls. First class jobs and cheap.
Sparkly pink
Metallic magenta
Pearlescent blue, going to be stripped and frame sold on as out grown
Glow in the dark, be seen, green
Pearlescent! that's the word I was after. Great finish on those Tracey & Wakefield's not a million miles away. Ta.
I got purple done with just a little sparkle coat over the top (Scotland though) so it can be done
[URL= http://i626.photobucket.com/albums/tt348/shawnmcfarlane/2-DSC03802_zpsc5ea2759.jp g" target="_blank">
http://i626.photobucket.com/albums/tt348/shawnmcfarlane/2-DSC03802_zpsc5ea2759.jp g"/> [/IMG][/URL]
got any pics of the full bike restlessnative? that looks good.
Always love the work of [url= http://www.fatcreations.com/ ]fatcreations[/url] on instagram.
Looks like the prices start from £150 from the website.
As bling as you can handle......but not powder coated 🙁
Can anyone explain the process to a simpleton like me?
I'd like my Cove re-done, but it'already been repainted once, very badly and it's flaking off on the edges - I'd like them to strip it, fill a small dent and recoat it - Argos Racing will do it, but they want 3 weeks and that's too long to be without my only bike.
LSN stripped the frame, masked it all up and then powder coated it all within a couple of days. Most we paid was £65 for the Reign which included the white bits. Was a few years ago.
Powdercoating melts a plastic powder to form a very tough coat.
Paint (or enamel) is solvent based (might be a hydrocarbon solvent, or might be water). Some are a reaction and made up of two parts (2k) which when mixed set. Paint is almost always the better quality finish (you wouldn't powder coat a car for example), but it is more fragile and chips.
Metalic finishes are made by adding various amounts of metal dust to the clearcoat on top, not the color otherwise you'd not see it. So strictly these aren't powdercoated, but can be applied on top of powdercoat as long as the temperature they're cured at is less than the powdercoat melts at.
Candy finishes are a dilute paint in clear lacquer over a silver or gold colored base coat (although you can do it with a colored base coat and top layer).
Pearl finishes are like a cross between the two, except using mica (ground up white rocks) not metal, in an otherwise transparent colored layer so you get a slightly milky color.
Hence why some powder coaters don't offer them, because they're not setup for doing clearcoats on top of their powder.
Thanks,
So, providing it's something they do, filling a smoothing a small dent doesn't stop them power coating would you say?
Stockport powder coating might be worth chancing, they do chrome finishes for car wheels and the like so might be able to sort some other finishes out. Also they do a fantastic job and give great service, highly recommend them!
there you go, rigid 69er purple sparkle nichemongering
[URL= http://i626.photobucket.com/albums/tt348/shawnmcfarlane/12143268_10207969658539081_3430928365638582554_n_zps3gjehdpi.jp g" target="_blank">
http://i626.photobucket.com/albums/tt348/shawnmcfarlane/12143268_10207969658539081_3430928365638582554_n_zps3gjehdpi.jp g"/> [/IMG][/URL]
Regarding filling I was told I couldn't fill a dent because the filler would just fall out during the powdercoating process (presumably the heat). I'm not sure if special fillers are available but it will be best to ask the company doing the job.
I would also ask them about masking off inside the bottom bracket, headset and any other threads. You cant use normal masking tape when powdercoating as it can burn and damage the nearby paint. You can use high temperature masking tape though so I would buy some and mask it myself before getting it coated.
The powdercoaters who did my frame had a massive bag of silicon bungs that fitted every orifice..
You can have dent's filled with brass by a framebuilder as it's steel. That'll easily withstand powdercoating.
Aerocoat.net these guys come highly recommend by me never had an issue and they do colourful chrome fads as well as sparkles and metal flake. I had a frame done in such an offensively bright green with gold flake and silver sparkles that I loved but everyone else hated
thanks CD, http://www.aerocoat.co.uk/ terrible website. No menu on each page. No prices and no address (It's great yarmouth) No info about turnaound times or business by post?
Owned a powdercoaters for twenty odd years now. We specialise in more industrial company to company work but am happy to help out if possible. I'm based in Wakefield and if you wanted to come down and have a look at some colours feel free. A rep came in last month with some new candy and sparkly colours which looked really nice. We also have a clear powder with a metallic flake that goes over any colour but tbh I'm not really a fan of it( but it looks great over bare steel!). Feel free to get in touch. Email in profile.
Oh to be on your bike in daylight..............I only ride mine in the dark so it is all black.
York Powder Coating [url=
colour changing paint [url=
