Potential Garmin is...
[Closed] Potential Garmin issue
8 Users
I’ve had Garmins for years, but have just had an odd sort of issue. Set off on a ride, following a route. Stayed in the route page & directions appeared as per normal. 3/4 of the way round I decided to check the time & while doing this it appeared that my time/distance travelled were zero. Sure enough the Garmin had recorded me starting the ride at home, then a gap until the time I’d changed pages & just records the last 1/4 of the ride.
Is it possible to follow a route without the ride actually starting? So did I forget to press start when navigating the route & is it possible to be following a route without the device recording?
This has never happened to me before but it may not be coincidental that this was my first ride with a refurbished unit (Edge 530)
Posted : 21/02/2021 5:12 pm
The unit will "move" the map around regardless of whether you are actually recording. Sounds like you didn't press the start button.
Posted : 21/02/2021 5:15 pm
Yes you can follow a route without starting your ride. A common mistake to make, I’ve done it.
I always start my ride then load the route now.
Posted : 21/02/2021 5:16 pm
Thanks guys. Never done that before & I’ve been using Garmins for yonks
Posted : 21/02/2021 5:19 pm
A really annoying feature this. Caught me out before and when showing a mate how to follow a route, it would have caught him out until I told him to check he'd pressed start.
Posted : 21/02/2021 7:45 pm
Some Garmins can be set to "always record", so it's worth going through the settings.
Posted : 21/02/2021 8:02 pm
You can set it to remind you to hit start when you reach a certain speed. Think the default is a shade under 10km/h. Saved me a couple of times 🙂
Posted : 21/02/2021 8:17 pm
 Bez
Oddly enough, for a day or two my Explore did actually have everything at zero even though it really shouldn’t have been. After a bunch of button bashing and some reboots it went away. Just another Garmin firmware glitch!
Posted : 21/02/2021 10:09 pm
*feature
Posted : 21/02/2021 10:41 pm
