Post mount to IS nu...
[Closed] Post mount to IS numpty Q
3 Users
Reba forks with postmount - old formular b4 brakes IS 140mm rotors
will a Hope PS to IS 140 adaptor work - looked on Merlin site and says something vague like will work with most brakes or do i need to look for Formular specific
thanks
Posted : 18/08/2009 10:19 am
Because it's a 140mm front caliper it'll just be mounted straight onto the standard IS disc mounts on the fork, so to attach them to the Rebas you'll need to find a 160 front PM to IS adaptor, which are usually as rare as hens teeth, usually you can only find ones which add 20mm onto the disc size...
So, you could try using one of them and fitting a 160mm disc...
Posted : 18/08/2009 10:45 am
Pretty sure they were 160mm front, 140mm back.
IS caliper -> Post mount fork will need [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]this[/url] adaptor. Note that this means you will need to run a 180mm rotor (assuming you had a 160mm before) as the mount adds 20mm to your rotor size.
so to attach them to the Rebas you'll need to find a 160 front PM to IS adaptor, which are usually as [b]rare as hens teeth[/b]
Thats cos they dont exist :0)
Posted : 18/08/2009 10:56 am
sorry wrong info just been and measured and front is a 160mm rotor
so a supplementary numpty q
- think i get above the size of the postmount plus adaptor will add 20mm
to position of caliper so will need bigger rotor
very happy to keep my old brakes as i'm not too heavy, pads are easy to change and i never have to bleed - so [numpty?]can i just use the existing caliper with a 20mm bigger rotor? (plus a PS to IS 160mm Hens Teeth adaptor)?[/numpty]
Posted : 18/08/2009 11:08 am
STATO.. the adaptors do exist... I have one on a set of forks at home, running 160mm B4's on a Manitou fork with PM. Got the fork off someone on here ages ago and initially thought I was going to have to get an adaptor and new disc, but the adaptor came with the fork, and it all just bolted up perfectly and no need for a new disc.
But I'll agree on the hens teeth not existing... 😉
Posted : 18/08/2009 11:21 am
antigee... yes, the existing caliper will work just fine with an adaptor and 180mm disc.
Posted : 18/08/2009 11:23 am
thanks
tried googling for a formula specific but no joy so will try this Hope Post to IS 160mm rotor adaptor [url] http://www.chainreactioncycles.com/Models.aspx?ModelID=13732 [/url] and then if caliper looks right but need a bigger rotor will fit - at least i now know the rotor size may be a problem as well as the adaptor!
Posted : 18/08/2009 1:28 pm
antigee that is the wrong adaptor, that one is for IS forks and Post mount calipers. You need the one i posted earlier and a bigger rotor, trust me, there is no other way to do it, sorry.
Posted : 18/08/2009 1:33 pm
thanks STATO - see what you mean - i've got the logic back to front on how they are described - i hate those little green links have to read carefully
Posted : 18/08/2009 1:58 pm
sorry should have made it [b][url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]BOLD[/url][/b] ;0)
Posted : 18/08/2009 1:59 pm
