Post mount adaptor ...
[Closed] Post mount adaptor , which one?
3 Users
Forks take 180mm disc with no adaptior
203mm icetec rotor
My 20mm post to post doesn’t fit.
Which post adaptor do I need? Ideally not an expensive Hope one.
Advice much appreciated
Posted : 06/08/2018 7:50 am
You want a 203 ppm (yours will be a pp2). There’s two versions a standard and Xtr if your buying a shimano one. The standard is fine and half the price.
Posted : 06/08/2018 7:59 am
If you have Hope brakes (possibly only the four pot calipers) Hope may be your best choice as the calipers don't fit many adaptors, they foul the centre section
Posted : 06/08/2018 8:53 am
Thank you for both your replies,
Posted : 06/08/2018 8:57 am
I Should also point out that you can almost certainly just shim out your caliper with 1.5mm of washers and it will be fine, no-one will die.
Posted : 06/08/2018 9:08 am
